Is anyone familiar with FoMoCo Engine Builders out of Milwaukee? |
9144me2enjoy |
Aug 19 2023, 02:27 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
They’re offering this for $7799.00….Is anyone familiar with this company etc.?
Outlaw Street Complete 2276cc Motor # MFC-CE2276OS Mofoco All new case engines are currently at a minimum of 24 weeks lead time. Rebuilt case engines are currently at a minimum of 16 weeks lead time. We are a family owned, performance, custom-build shop... and quality takes time. Buy with confidence directly from the engine builder. Mofoco has over 55 years of experience in the VW industry building aircooled VW engines. Outlaw Street Complete 2276cc Motor This is the Complete version of our most popular stroker motor configuration. The 2276cc Outlaw Street Motor built by Mofoco to be the best street performance motor you can buy. It delivers the horsepower you are looking for, but still has the reliability you need. This motor is built with all new components and features Mofoco's exclusive 050 heads with D-shaped intake ports and is also the only VW aircooled cylinder head completely manufactured in the USA.All motors are priced with no exhaust so you can choose the option that best fits your needs Features: New Magnesium Engine Case New 82mm 4340 Chromoly Counterweighted Crankshaft New 94mm Pistons & Barrels New Chromoly I-Beam Rods New Lifters New Engle W120 Performance Cam New Mofoco "050" cylinder heads D - Shaped intake port; made purely in USA! New Dual Weber 44 Carburetors 12LB Forged Lightened Flywheel - 8 Dowelled New Solid Rocker Shafts New Stock Doghouse Fan Shroud New Doghouse Oil Cooler New Alternator New Filter Pump with spin on oil filter New 009 Distributor New Fuel Pump Test run and tuned before leaving our facility All engines come with a 12 month warranty. All Motors are Test Run at our facility before going out the door. With a complete, its the best way to go because we do all the initial work and all you have to do is the install. We run the motor for one to two hours and check anything and everything possible. We check the valves 2-3 times, we set the timing, adjust and sync the carbs, check the compression, check the oil pressure, and the initial break-in on the cam is done. |
Freezin 914 |
Aug 19 2023, 02:34 PM
Senior Member Group: Members Posts: 862 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Yes, I am not an expert, but familiar. Pretty much VW guys. They do know their stuff, been around a long time.. But, with that being said, I have heard mixed reviews. Good and bad.
Aug 19 2023, 02:37 PM
Is that a type 4 motor?
9144me2enjoy |
Aug 19 2023, 03:06 PM
It appears they are mostly a VW engine builder so I would assume its a Type 3 but not sure from the ad.
9144me2enjoy |
Aug 19 2023, 03:07 PM
Vs 2270-145 Type 4 Conversion Engine Kit
$7,495.00 from InEngineering Type 4 store for just a kit. |
9144me2enjoy |
Aug 19 2023, 03:08 PM
https://www.mofoco.com/item_images/banner.jpg. Picture of engine advertised Mofoco. Will call them Monday to verify if its a Type 3 or 4 engine etc.
Superhawk996 |
Aug 19 2023, 03:19 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Magnesium engine case definitely isn’t a T4 motor
9144me2enjoy |
Aug 19 2023, 03:20 PM
I’m pretty sure its going to be a Type 3 but still a fair price if one was in the market for a Type 3 build. Thanks for the comments…….
914Sixer |
Aug 19 2023, 04:55 PM
Check the BBB on them. They used to be not recommended.
Not so on magnesium cases. SOME Euro cases stamped "VO" were made of magnesium Attached thumbnail(s) |
Freezin 914 |
Aug 19 2023, 05:51 PM
I did not look very long… but seen this. It is a type 4
930cabman |
Aug 19 2023, 06:04 PM
Advanced Member Group: Members Posts: 3,064 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Magnesium case, not for me.
From what I know mag cases are inferior to aluminum. Ask an owner of a 7R case from the early 1970's 911. The main bearing bores oval over time much more than comparable aluminum cases. |
9144me2enjoy |
Aug 19 2023, 07:54 PM
Good information to know, thanks
nditiz1 |
Aug 19 2023, 08:12 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Back in the day they were cheap and i steered clear of any mofoco heads. They always seemed to have issues, but that was type 1 heads and 20 years ago so....do research of recent quality
wonkipop |
Advanced Member Group: Members Posts: 4,299 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Check the BBB on them. They used to be not recommended. Not so on magnesium cases. SOME Euro cases stamped "VO" were made of magnesium 1968 411 only. unlikely any of those cases ever got to the USA. 411s didn't get stateside until about 71 or something. they stopped making them mag for a sound reason i imagine. |
Superhawk996 |
Aug 20 2023, 10:37 AM
Not so on magnesium cases. SOME Euro cases stamped "VO" were made of magnesium Hmm - never knew of a VO case. Don’t imagine I’ll ever see one in my lifetime Always something to learn on this site (IMG:style_emoticons/default/beerchug.gif) |
Superhawk996 |
Aug 20 2023, 10:41 AM
Magnesium case, not for me. From what I know mag cases are inferior to aluminum. Ask an owner of a 7R case from the early 1970's 911. The main bearing bores oval over time much more than comparable aluminum cases. Unless you want lightweight - that is the advantage of Mag. |
brant |
Aug 20 2023, 11:05 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Magnesium case, not for me. From what I know mag cases are inferior to aluminum. Ask an owner of a 7R case from the early 1970's 911. The main bearing bores oval over time much more than comparable aluminum cases. Unless you want lightweight - that is the advantage of Mag. Agreed We ran a 1966 2.0/6 aluminum motor Switched to a 73.5 mag 7R race 2.0/6 Loss about 20lbs |
Porschef |
Aug 21 2023, 05:57 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Bit of a hijack but whatever happened with Original Customs? I know it was a little while ago but from what I recall his $5k engine was a pretty good deal.
Haven’t seen McMark here in some time it seems... |
Aug 21 2023, 06:08 AM
I think sir Andy mentioned he has a real job and does the car stuff on the side. @sirandy .
Aug 21 2023, 09:26 AM
McMark is closing up his shop ...
(IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:12 PM |
