Head rebuild advice for 103mm cut heads, Reweld or buy new, who's running 103? |
nditiz1 |
Aug 22 2023, 07:36 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
EDIT: Head is toast. Looking to source replacement ones. So I'm tearing into the FAT perfomance 2.6 engine. I was going to try to run it, but before that went to perform a leak down and saw a gaping hole in #4 next to the plug. I just removed the head and it looks good other than previous welding I assume FAT did when the built the heads. There is little material amount between the camber and the edge of the head due to the cut of 103 P&C. Is this just the evil of hipo engines or are better options out there? Should I have these rewelded OR buy new 103 cut heads? Who out there is running big power? Also I know Raby spoke highly about FAT engines, but damn did they love RTV. |
Mikey914 |
Aug 22 2023, 10:42 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'd start with new metal. Only way to know for sure you will not have issues in the future in this area. Had to have been real loud.
technicalninja |
Aug 23 2023, 10:50 AM
Senior Member Group: Members Posts: 1,217 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
That's TOAST in my book.
Wow! that had FIRE shooting out of it... Those heads are "organ doners" for me and I'd be real nervous about the valves in the destroyed chamber. |
Mikey914 |
Aug 23 2023, 05:39 PM
Yes thermal failure “crystallizes “ that’s why you don’t know to what extent the damage is. More than likely, and if you could definitely identify, a significant portion would need to be removed, and additional machining and welding costs would outweigh any savings, with a big question of how long will the repair last?
rhodyguy |
Aug 24 2023, 08:00 AM
Does this mean the case was opened up for the 103 clys?
nditiz1 |
Aug 24 2023, 10:58 AM
Mikey914 |
Aug 24 2023, 01:02 PM
Size is ok, add additional oil capacity with an offset cooler and a temp gage. I wouldnt go any bigger, but its managable.
Replace the head and drive. (IMG:style_emoticons/default/driving-girl.gif) |
porschetub |
Aug 24 2023, 03:53 PM
Size is ok, add additional oil capacity with an offset cooler and a temp gage. I wouldnt go any bigger, but its managable. Replace the head and drive. (IMG:style_emoticons/default/driving-girl.gif) Don't think it just as easy as bolting on another head,expect you need to get FAT to make another one up to match the other side ,numbers on the head would indicate specs I would say ?. Then there is the question of how long will the remaining head hold up if the combustion floors are really thin as the OP mentioned ?. Perhaps a reduction in CR may make them last longer but don't know in this case . The effected cyl looks to have been running lean but hard to say if that was caused by the hole or detonation previously. Remember back when I bought a set of heads off a well known builder in my country and needed them flycut for compression increase and he mentioned you can't cut then too deep with the big cylinders but with mine that was not an issue. Don't think the solution is that straight forward. |
rhodyguy |
Aug 24 2023, 06:17 PM
Buy an unaltered case.
Mikey914 |
Aug 24 2023, 06:39 PM
Size is ok, add additional oil capacity with an offset cooler and a temp gage. I wouldnt go any bigger, but its managable. Replace the head and drive. (IMG:style_emoticons/default/driving-girl.gif) Don't think it just as easy as bolting on another head,expect you need to get FAT to make another one up to match the other side ,numbers on the head would indicate specs I would say ?. Then there is the question of how long will the remaining head hold up if the combustion floors are really thin as the OP mentioned ?. Perhaps a reduction in CR may make them last longer but don't know in this case . The effected cyl looks to have been running lean but hard to say if that was caused by the hole or detonation previously. Remember back when I bought a set of heads off a well known builder in my country and needed them flycut for compression increase and he mentioned you can't cut then too deep with the big cylinders but with mine that was not an issue. Don't think the solution is that straight forward. It really should not be too hard to use new metal and machine to match. I would find a reputable machine shop and go from there. Unless it’s under warranty. |
crash914 |
Aug 25 2023, 07:32 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
I have at least one set of 103 cut heads. A couple of small cracks around the valve seats. I also think i have a couple of rebuildable core heads for stockish cylinders.
You are welcome to swing by and take a look. I should be home all weekend except for a dump run Saturday early am. herb |
Al Meredith |
Aug 25 2023, 08:59 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
If I remember correctly Jake didn't like 103s because the cooling fins are smaller than on a stock engine in order to fit under the stock cooling tin. Since they fun hotter it is necessary to use a remote oil cooler. He told me that a 2056 is about the biggest you should go with a stock oil cooler. I've talked to Len Hoffmen about welding a crack on an aluminum head . To do this correctly the head mist ne warmed to 1000 degrees F ( I could be wrong about the temps) do your welding and then bring the head back very slowly . Just my 2 cents. Al
nditiz1 |
Aug 25 2023, 12:07 PM
Herb! I totally forgot how you love running the hipo T4. Might stop by Sunday, I'll text you.
Lo-Fi Version | Time is now: 16th May 2024 - 02:18 AM |
