Aero questions. |
Aero questions. |
jmz |
Sep 2 2023, 10:49 AM
Member Group: Members Posts: 165 Joined: 11-April 16 From: Lone Star State Member No.: 19,886 Region Association: None |
brant |
Sep 2 2023, 03:50 PM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Green looks great!
Love the tire source decal That’s actually the shop I met Dave ferguson at And they are closed now But the absolute best tire shop there has ever been |
mgp4591 |
Sep 3 2023, 12:26 AM
914 Guru Group: Members Posts: 5,370 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Does this tail even do anything? Decided to run the car with air dam and “tail” at next weeks race. Been running in standard GT configuration most times. (Recently repainted back to original green) Good looking car! I would think that the speed would make a big difference. There was a study a few years back that indicated that the outer edges of the rear were the best spots for downforce while having the center of the trunk area "spoiled" as well will reduce the straightline speed because of too much drag. |
Brett W |
Sep 3 2023, 06:29 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Do you have a good way to quickly adjust the angle of attack?
jmz |
Sep 3 2023, 08:14 PM
jmz |
Sep 3 2023, 08:16 PM
Green looks great! Love the tire source decal That’s actually the shop I met Dave ferguson at And they are closed now But the absolute best tire shop there has ever been That’s Dave’s photo from the SCCA log book I have. I tried to get into the reunion and if it mattered would have used that livery. It’ was really hard to get in this year and they didn’t accept the car… |
BillJ |
Sep 3 2023, 08:20 PM
Senior Member Group: Members Posts: 1,096 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
I thought you had to have a car that was raced pro in period?
jmz |
Sep 4 2023, 01:53 AM
Charles Freeborn |
Sep 6 2023, 02:31 PM
Member Group: Members Posts: 249 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Many of the "period correct" restrictions are being lifted as organizations are desperate for entries. Several of the mods to my car (crank fired ignition, big brakes, etc) are overlooked now. I don't know if that' a good thing, but for me I'm only interested in having fun so if someones car is better prepped than mine, c'est la vie.
stownsen914 |
Sep 8 2023, 07:27 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Yes a spoiler like that will be effective. A more vertical stance would be more effective, which might be what Brett was getting at. Air over the rear deck of a 914 is pretty turbulent, made worse by the sharp dropoff and void behind the roof. A spoiler helps direct the air and give moderate downforce.
yeahmag |
Sep 8 2023, 11:39 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
914sgofast2 |
Sep 11 2023, 06:00 PM
Senior Member Group: Members Posts: 616 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
From that study it looks like adding a rear spoiler without drastically lowering the car only costs you horsepower! |
sixaddict |
Sep 12 2023, 04:03 PM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
I have been told as much by several people……but here’s a couple of points.
When buying the front spoiler from Sheridan he asked me how will I compensate out back. To me that meant I needed ( and had ) a wing. Secondly, from experience the car was much more stable in high speed turns….. ex: turn 9 at Road Atlanta is flat out Without wing it would “dance” across the track whereas with wing it held the line even as the track drops down…. To me the down force (stability ) was worth the potential loss of top end……purely anecdotal but I guess seat of the pants can lie. FWIW |
stownsen914 |
Sep 23 2023, 08:29 AM
I'm finding that aero study a little hard to understand. The spoiler and wing configurations are listed as having negative values in the Downforce column. One way to interpret that is that they are providing "negative lift" which is what aerodynamicists call downforce. The wing and spoiler configurations both show negative values in the Downforce column. These should be higher downforce configurations, so I assume negative values mean negative lift i.e. downforce? Which would match conventional wisdom that these add-ons provide downforce.
technicalninja |
Sep 23 2023, 10:10 AM
Senior Member Group: Members Posts: 1,208 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I am a member of hybridz.org, a Datsun Z car forum.
Years ago, one of the members rented a NASCAR wind tunnel for a weekend and tested various aerodynamic devices on an early Z (pre-79). Zs are worse aerodynamically than a 914. The side view of the car shows the entire body forms a high camber wing that creates a serious amount of lift above 60mph. The faster you go the worse it gets! A stock 240Z gets dangerous above 125 mph. Spoilers attached to the rear of the car (similar to the OPs set up) helped to REDUCE this lift but did not create any down force at all. They helped but were not the solution. A simple air dam up front created significant down force on the front of the car. Enough down force to un-balance it. Adding a 1" splitter doubled the down force and a 3" splitter tripled it! Stuff on the front of the car worked bad-assed. Everything made down force! What they had to do on the rear of the car to attain enough down force was a big assed wing at or above the top of the car. By the time they achieved balance with the 3" splitter the wing was HUGE. Wider than the car, above the roof line, and looking like something out of the Japanses bosozoku world. It would be ok on a trailered race car but not for a streetcar. It was an "in your face" super wing! Balancing any frontal device takes either a big obnoxious wing, properly designed rear diffuser or maybe both. The diffuser is the first place to start on a Z. They did not have a diffuser for the Z when they tested in the wind tunnel. Zs don't have much room for a diffuser. The rear suspension is in the way. 914s are far more adaptable for a rear diffuser than a Z IMO. Z cars are not 914s and the overall shape is different but aero is aero and a functional rear downforce device is either going to be a well-designed diffuser or a BIG ASSED wing in smooth air in my book. One thing to remember. If you're making 400lbs of down force the bracing for the wing has to transfer that to the chassis and needs to be MEATY. Two 200lb men should be able to jump up and down on the wing at the same time. Same thing with the diffuser, it's going to be pulling on the bottom of the car with great force. You should be able to hang a couple of 200 lb. men off of it with the car in the air on a lift. Diffusers usually beat wings in the downforce/drag department. Almost ALL aerodynamic devises for downforce create drag. There is no free lunch. |
windforfun |
Sep 23 2023, 03:11 PM
Senior Member Group: Members Posts: 1,780 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I would go with an inverted F35 design. I'm sorry, but I couldn't resist. I'll leave now.
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 01:25 AM |
