7x15 ATS Classic ET offset 16, Will these fit 1972 914 |
Milo914 |
Sep 4 2023, 03:51 AM
Newbie Group: Members Posts: 2 Joined: 4-September 23 From: Australia Member No.: 27,563 Region Association: Australia and New Zealand |
Hey guys new to the forum, thanks for the add. (IMG:style_emoticons/default/smile.gif) I’ve found these ATS wheels and wondering if they will fit with 205/55/15 tyres.? The originals are 5.5x15 et40 and I’m not sure if the extra wheel width will make up for the smaller offset of 16? Tia
Milo914 |
Sep 4 2023, 04:31 AM
Hey guys new to the forum, thanks for the add. (IMG:style_emoticons/default/smile.gif) I’ve found these ATS wheels and wondering if they will fit with 205/55/15 tyres.? The originals are 5.5x15 et40 and I’m not sure if the extra wheel width will make up for the smaller offset of 16? Tia I’ve done some research on offsets and some calcs and I’ve come up with I need an extra 40mm clearance off the back of the wheel. Happy to be corrected by those that know about this…..The front of the wheel appears to sit in roughly the same position less 5mm as the stock steel. |
Shivers |
Sep 4 2023, 04:48 AM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
(IMG:style_emoticons/default/welcome.png) Welcome- with a backset of only 16mm, compared to 40mm it is going to push your wheel into the fender almost an inch (24mm).
Chris914n6 |
Sep 5 2023, 04:02 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Standard Porsche 15x7 is 23.3mm offset, which sometimes fits the rear stock fenders depending on how skinny the tire is.
I'd say the ones you found would fit with flares but not as is and definitely not with 205/55. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:27 PM |
