Locked Gearbox, Can't turn by hand at the stub axles |
poorsche914 |
Sep 9 2023, 05:33 PM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
In preparation for Okteenerfest, I finally resealed one of my leaking gearboxes and planned to get it installed this weekend. Was having difficulty mating it to the engine so pulled it back out and found I cannot turn it by hand when in gear - I tried them all. In neutral, I can turn the stub axles in opposite directions and hear the gears moving and the shaft does not spin.
On the gearbox I took out, I can rotate the stub axles and the shaft spins (guessing it is in gear but not 100% sure). Can't easily change gears on it since I removed the shift console to use on the resealed unit. When I resealed the 'box, I removed the stack to change the shaft seal. Put everything back in and didn't have any leftover parts (IMG:style_emoticons/default/wacko.gif) Even watched Dr Evil's video. Any ideas on what might be going on? (IMG:style_emoticons/default/driving.gif) |
poorsche914 |
Sep 9 2023, 06:36 PM
UPDATE: I removed the nose cone and everything moves as it should in/out of gear. But when I replace the nose cone... it binds.
What should I look for? I have removed/replaced nose cones before without issue. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/driving.gif) |
Superhawk996 |
Sep 10 2023, 07:29 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If I recall there is a spacer / thrust washer that can cause jamming of 1st and reverse if not installed in correct orientation?
poorsche914 |
Sep 10 2023, 11:17 AM
If I recall there is a spacer / thrust washer that can cause jamming of 1st and reverse if not installed in correct orientation? You are correct! I had the flat bearing on the wrong end (IMG:style_emoticons/default/dry.gif) Thanks for the suggestion. I figured that's what it was when I removed the nose cone from an extra gearbox and saw the order. Just got things swapped and works as it should. Gearbox is mated to the engine. (IMG:style_emoticons/default/driving.gif) |
Superhawk996 |
Sep 10 2023, 11:43 AM
Just got things swapped and works as it should. Gearbox is mated to the engine. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/smilie_pokal.gif) Good job! |
Lo-Fi Version | Time is now: 15th May 2024 - 01:09 PM |
