FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,964 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,184 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Best I can do
Attached thumbnail(s) ![]() |
FlacaProductions |
That may the the (only) way to go.
I think it may be the original that’s in there now. Amazing. Should I get continuity between the top center (where the coil wire sits) and the outer tip that would sweep through the plug wire locations? Seems I should….but I do not with the one that’s in there now. EDIT - I now know that I should only get continuity when the centrifugal arm is extended. This is the case but I still have suspicions about this piece. If only because of its age. Big thanks for this. |
914Sixer |
Rev limit rotors rarely fail. Heat is the big enemy.
FlacaProductions |
We just can’t figure out why we have a crank but no start situation.
No spark. |
914Sixer |
You can put a stock VW/914 rotor on it and see what happens. Found a cheaper option. Later style but works fine.
FlacaProductions |
Will that one fit? I've seen some notes that "new/other" ones fit loose on the distributer shaft....i've also learned: the Bosch 1234332159 is an original distributor rotor for the Bosch JFDR6 0231159001 distributor used since 01/66 for 911 normal, 911T and 911L.
EDIT: just decided to go like-for-like and got the ebay NOS one. Even if it ends up not being the issue, having a spare of a rare part isn't all bad. Although...a 123 is probably the real way to go in the long run. but right now, just want to get it to start again. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,199 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
We just can’t figure out why we have a crank but no start situation. No spark. Test coil alone for spark. Then test with rotor / distributor / plug wires If you know you have spark at the coil but then it doesn’t make it out to the plugs you now know which side of the system the problem is on. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,905 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
That rev rotors been messed with, add a non rev rotor ..be Happy.. dont throw a brick on your gas pedal ..you'll be fine..
FlacaProductions |
@sixnotfour - can ya find me a non-rev rotor?!
sixnotfour |
FlacaProductions |
Alllllrighty then!
I've read that many/some of the new ones are loose on the shaft but at that price, worth a swing. Thank you. (btw...how can you tell that original rotor has been "messed with" - not doubting it since it's the original....just wondering what you see.) |
sixnotfour |
its missing the spring and spring cup... BTW mine stuck grounded on a drive by of the corvette dealer,, high speed dow shift,,,towed it home ..to go WTF..
Lo-Fi Version | Time is now: 4th July 2025 - 05:05 AM |
