| FlacaProductions |
Sep 21 2023, 06:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,181 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
| FlacaProductions |
Sep 21 2023, 07:08 PM
That may the the (only) way to go.
I think it may be the original that’s in there now. Amazing. Should I get continuity between the top center (where the coil wire sits) and the outer tip that would sweep through the plug wire locations? Seems I should….but I do not with the one that’s in there now. EDIT - I now know that I should only get continuity when the centrifugal arm is extended. This is the case but I still have suspicions about this piece. If only because of its age. Big thanks for this. |
FlacaProductions OT: 67 non-S 911 Distributor Rotor? Sep 21 2023, 06:07 PM
914Sixer Best I can do Sep 21 2023, 06:53 PM
914Sixer Rev limit rotors rarely fail. Heat is the big ene... Sep 21 2023, 08:27 PM
FlacaProductions We just can’t figure out why we have a crank but... Sep 21 2023, 10:45 PM
Superhawk996
We just can’t figure out why we have a crank bu... Sep 22 2023, 12:45 PM
914Sixer You can put a stock VW/914 rotor on it and see wha... Sep 22 2023, 08:05 AM
FlacaProductions Will that one fit? I've seen some notes that ... Sep 22 2023, 08:35 AM
sixnotfour That rev rotors been messed with, add a non rev ro... Sep 22 2023, 03:03 PM
FlacaProductions @sixnotfour - can ya find me a non-rev rotor?... Sep 22 2023, 07:27 PM
sixnotfour
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 22 2023, 08:26 PM
FlacaProductions Alllllrighty then!
I've read that many/so... Sep 23 2023, 08:56 AM
sixnotfour its missing the spring and spring cup... BTW mine ... Sep 24 2023, 02:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th April 2026 - 11:05 PM |
