dwelle |
Newbie ![]() Group: Members Posts: 13 Joined: 24-December 16 From: a town south of fresno Member No.: 20,693 Region Association: None ![]() |
so, the ignition cylinder in my '71 recently quit working, it won't rotate. the ignition key won't quite go in all the way, yet a second, different key will. further, the plate/tab on the back of the cylinder that rotates the column switch has a small piece that is broken off.
part is 914.347.019.00. a quick look online at the usual places only reveals some cheap looking alternatives: http://www.autoatlanta.com/results.php?par...er2=91434790300 it looks like auto atlanta will rekey new cylinder to existing key: http://www.autoatlanta.com/tinyresults.php...0&width=875 i would prefer to keep the orginal part in there if i can repair or even rekey it. the broken plate/tab probably can continue to work fine given how tight everything is inside the cylinder. i can't imagine i'm the first guy to have this issue. what are my options? i'd happily buy a working used one if i could find one... ![]() ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I used JB weld on mine and it’s held together. That’s all I got.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,197 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
@theCabinetmaker . He should be able to help.
dwelle |
genius. thank you!... |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
It's your lucky day. I found one!
dwelle |
Lo-Fi Version | Time is now: 18th July 2025 - 07:00 AM |
