WTB 901 transmission "H" gear set, And 904 main shaft |
Driver174 |
Oct 3 2023, 09:29 PM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
As title states I am wanting a "H" gear set for my race car.
Jim |
mlindner |
Oct 4 2023, 03:51 AM
Senior Member Group: Members Posts: 1,531 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Have you checked with Dr. Evil.
Steve |
Oct 4 2023, 01:32 PM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
https://www.cogscogs.com/Transmission-914-M...Speed_c_92.html
I bought my H gear from these guys, but check with Dr. Evil First. Dr. Evil also set me up with a taller 3rd and 4th to match the H fifth for my SBC conversion. The gears feel like a stock transmission, roughly 1500 rpm's between gears. |
Chris914n6 |
Oct 4 2023, 02:30 PM
Jackstands are my life. Group: Members Posts: 3,339 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
'H' gear is used by v8 swappers as a high 5th gear for cruising. It's gotten hard to source now as it was only used on 911 4 speeds.
I don't think you want the tall OD gear for racing so it would be cheaper & easier to pick a different gear set. |
Driver174 |
Oct 4 2023, 03:30 PM
H gear set will be taller 2nd gear for slow rolling starts. The last time I used 2nd during a race start, I spun the engine really high. I was on pole and slowed everyone down. It work out well for me but I’m thinking a taller gear will work better.
Steve |
Oct 4 2023, 03:57 PM
H gear set will be taller 2nd gear for slow rolling starts. The last time I used 2nd during a race start, I spun the engine really high. I was on pole and slowed everyone down. It work out well for me but I’m thinking a taller gear will work better. You do know that a 914 trans has a fixed 2nd gear and can't be changed. You would have to replace the 914 mainshaft with a 904 mainshaft which allows you to change 2nd gear. |
Driver174 |
Oct 4 2023, 04:10 PM
You are correct Steve; I forgot about that. I guess I need a 904 main shaft as well.
brant |
Oct 4 2023, 06:06 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I think…. But do not know for certain as I have not tried an H gear
That h will not fit inside the case in 2nd possibly My 2nd is J I assume slightly larger than H And the case had to be machined inside to make the room Plus. The machining opened a window in the case Causing the window to have to be welded closed And you have to remove reverse to create the space for the width of the gear. Plus the 904 main shaft So it all turns into a 10K transmission when your done with rebuild and cooling Not a bolt in job by any means I haven’t tried H though But I run F J O S V |
sixnotfour |
Oct 4 2023, 07:35 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
G-box in Erie Co. has a bunch of ratios..
stownsen914 |
Oct 5 2023, 09:32 AM
Senior Member Group: Members Posts: 916 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
There are a couple options to do what you want to do:
- H on a 904 mainshaft as suggested. Great option. 904 mainshafts are pricy, and the gearsets are unique to them, i.e. a regular H from a 4 speed won't fit a 904 shaft. - You can also have a stock F mainshaft turnd down and an H welded onto it (and the other gear just goes into place on the pinion shaft, no mods). I have a "KA" second (stock 914 5th gear ZD flipped and welded to a stock shaft in the second gear position. I've run this for years, no machining was needed to the case. - Consider a GA second. This was a stock gear on 70-71 911s, so much more plentiful than a 904 shaft, and almost as tall as an H. Might be worth checking a gear chart to see if it could work for you. |
Driver174 |
Oct 5 2023, 09:57 AM
There are a couple options to do what you want to do: - H on a 904 mainshaft as suggested. Great option. 904 mainshafts are pricy, and the gearsets are unique to them, i.e. a regular H from a 4 speed won't fit a 904 shaft. - You can also have a stock F mainshaft turnd down and an H welded onto it (and the other gear just goes into place on the pinion shaft, no mods). I have a "KA" second (stock 914 5th gear ZD flipped and welded to a stock shaft in the second gear position. I've run this for years, no machining was needed to the case. - Consider a GA second. This was a stock gear on 70-71 911s, so much more plentiful than a 904 shaft, and almost as tall as an H. Might be worth checking a gear chart to see if it could work for you. Does the GA ratio utilizes the same 18 tooth main shaft gear and just a 32 tooth gear is needed? If that is the case then it looks to be my best option. |
brant |
Oct 5 2023, 11:03 AM
GA main shaft is a full shaft replacement(two gears)
It is also a fixed gear main shaft but a different ratio than the stock F They are much cheaper than a 904-main Probably around 500$ these days |
GregAmy |
Oct 5 2023, 11:06 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I'm running A-H-N-U-ZA on my four-banger historics car. Seems to work well for me.
I did not use a 904 shaft. Instead, a known shop* lathed the F gear off my 901 shaft and hand-cut the splines on the shaft to make the gear fit. Welding would work, too, but that negates my ability to easily swap gears in the future. And would it need to be heat-treated? GA *I'm only offering this to demonstrate that it can be done. I hesitate to offer the name as I don't know if he'd want to get asked by others for that service, it took a lot of his time. |
stownsen914 |
Oct 6 2023, 05:40 AM
Exactly my point about the GA, it's a cheaper option since it was a stock production ratio. Agreed you should be able to find a good one for a few hundred $.
For the welding option ... technically the shaft and gear should probably be annealed before welding and then heat treated afterward. Not sure what specs though, you might be able to get the info though. I'd worry about deforming the shaft during whatever quench phase would need to be done and winding up with runout in the shaft. I've known a number of people who have welded gears to 901 mainshafts, and when I inquired about heat treating, all of them said to not worry about it - just weld it and be done. I've run a welded shaft behind 250 hp for years without issue. |
Lo-Fi Version | Time is now: 11th June 2024 - 07:37 PM |
