Value of 1.8 engine with exhaust system and full FI system, What's it worth? |
Oct 10 2023, 06:54 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Have you finally put the 930 turbo motor into the 914? Hopefully the motor will be out of the 930 soon. Just finished installing my lift. Besides stripped #2 plug the motor leaks oil virtually everywhere there's a pipe. I thought about how the motor would fit in the 914 but not sure where the turbo would be located. You know you want to. |
VaccaRabite |
Oct 11 2023, 05:57 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I would not buy the 1.8 unless you needed it to get your car running.
Like others - the 1.8 is the worst of the three engines the 914 came with. Unless you are planning to use it to build a larger, better engine (and you can totally do that and retain most of the l-jet) I would not touch it. Just another engine you would have to store somewhere. Zach |
windforfun |
Oct 11 2023, 02:11 PM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Very nice lift indeed. You can eliminate the overhead garage door opener by going with a rig made by Chamberlain. It mounts on the wall & attaches to the door's torsion bar. It's $500 at Home Depot. CTTOI, does your door have a horizontal torsion bar? I don't see one. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) No just the typical coil springs on each side. I got that opener from Home Depot. It's by Sommer and is the quietest opener I've ever heard. It is a direct drive opener with a 24V dc motor in the carriage. The control unit is just a ac/dc power supply and ECU. The carriage picks up power from a stationary chain. That's an interesting design. It's counter intuitive I suppose. Here's a pic of my wall mounted rig. It's super easy to install & nothing drips on the car. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
jhynesrockmtn |
Oct 11 2023, 07:57 PM
Member Group: Members Posts: 420 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
If you have a nice 1.8 with original injection and can pick up a spare fairly cheap, go for it. I have both a 1.7 with original injection and a 2.0 with the same. Sure, the 2.0 has more HP but in good tune the 1.7 and 1.8 can move these little cars along just fine. My little 70 1.7 is plenty fun to drive. I've raced FV for several years, so the definition of a "momentum car" :-) I'm used to trying to move a low horsepower car along as fast as it will go.
wonkipop |
Oct 12 2023, 01:41 AM
Advanced Member Group: Members Posts: 4,401 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
If you have a nice 1.8 with original injection and can pick up a spare fairly cheap, go for it. I have both a 1.7 with original injection and a 2.0 with the same. Sure, the 2.0 has more HP but in good tune the 1.7 and 1.8 can move these little cars along just fine. My little 70 1.7 is plenty fun to drive. I've raced FV for several years, so the definition of a "momentum car" :-) I'm used to trying to move a low horsepower car along as fast as it will go. (IMG:style_emoticons/default/beerchug.gif) |
fiacra |
Oct 12 2023, 12:03 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 344 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
If you have a nice 1.8 with original injection and can pick up a spare fairly cheap, go for it. I have both a 1.7 with original injection and a 2.0 with the same. Sure, the 2.0 has more HP but in good tune the 1.7 and 1.8 can move these little cars along just fine. My little 70 1.7 is plenty fun to drive. I've raced FV for several years, so the definition of a "momentum car" :-) I'm used to trying to move a low horsepower car along as fast as it will go. Yes, lucky enough to have one of the cleanest 914's I've seen. Looks like the previous owner kept it in the garage with a cover. Picture is from when I first got it two years ago. It look exactly the same today as then. (One long needed change is in the works with a set of Fuchs about to go on it.) One owner for 44 years with all maintenance records. Not the original paint, but a really high quality paint job that has held up really well over the years. I also like the look of the early 911 mirrors. Having a low horsepower car has not been an issue for me. I just love having a car that makes (almost) everyone smile and is not a major project. Yes, it "speeds up" when you push the accelerator rather than "accelerating" like the 2.0 in my bumblebee does, but so what (IMG:style_emoticons/default/confused24.gif) At least I get to drive it rather than having a debate about which type of jackstand is the best to keep it on (IMG:style_emoticons/default/biggrin.gif) Having another drivetrain and all the components to make sure I have everything I need to keep that part of the car roadworthy seems like a good idea. The engine and everything that comes with it is priced well (thanks again to everyone who chimed in on value) so I think I will go ahead and commit to the deal. Clearing room in our second garage this week-end. OK, we can go back to our discussion about garage door openers now (IMG:style_emoticons/default/av-943.gif) |
Spoke |
Oct 12 2023, 01:40 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Very nice looking 914. Good move with the Fuchs.
windforfun |
Oct 13 2023, 12:34 PM
"OK, we can go back to our discussion about garage door openers now."
I always wanted to hijack a thread. Finally, at last... (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
Geezer914 |
Oct 13 2023, 01:17 PM
Geezer914 Group: Members Posts: 1,443 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
If you plan on building a 2056 with Ljet, then go for it. You still need a 2.0L crank & rods.
Lo-Fi Version | Time is now: 7th June 2024 - 09:10 PM |
