Well, I did a thing, It was a thing I knew better then to do, too. (Thermocouple connecting) |
VaccaRabite |
Oct 11 2023, 06:22 AM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Continuing to live my life as an object lesson for others...
I recently had to pull my engine for some repairs. For me, part of pulling the engine includes removing the thermocouple from under the #3 spark plug and fishing it out of the engine tins. This runs to the CHT gauge in the cabin of the car. And we all know you are not supposed to cut the wire. Everybody knows that. So I figured I'd cut the wire, add a nice weatherproof automotive plug, and see what happens. All in the name of convenience and curiosity. I drove 300 miles last weekend. Including going fast up a really long couple of hills (like miles long hills) in 5th gear. So the results.... At cold start, the gauge reads the same as ambient temps. Under normal driving, the CHT gauge read slightly cooler then before I added the plug, but within 10 degrees of what I expected. However, when pushing the car, the error rate grew exponentially. Where I would expect the car to be running 340-350 head temps, the gage only showed about 300. And pushing 90 up hill in 5th for over a mile I would expect the gage to read 360+ the gage only ever got to 325. I did not push past what I know this engine required to get to 375 (which is my back off point). The result of this experiment is that if I did not know and expect bogus returns on the gage, I could easily roast an engine and start dropping valve seats, while a quality CHT gage was reporting I was WELL under the 400 degree danger zone. I have another cable I can swap in. Kind of a pain, but not a huge deal. I'll add it o the maintenance schedule. But, yeah. In this case the group think is accurate. The very slight resistance that the plug will add to the cable will be enough to throw off your CHT monitor. Do not cut the line between the thermocouple and your CHT gage. Zach |
nditiz1 |
Oct 11 2023, 07:00 AM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I'm guessing you didn't have a setup similar to the dakota digital? That thermocoupler has disconnects already built in. With that in mind I'm surprised your setup would be much different. I don't know much about the inner workings of thermo dynamics just that heat is transferred via these two wires to the gauge. I guess if the metals were dissimilar in your connection points that would cause a discrepancy. Good to know though about other types of CHTs.
Spoke |
Oct 11 2023, 07:36 AM
We just temperature tested a unit we're designing using 7 thermocouples. The logging device we connected to just had terminals with screws to attach the thermocouples. The thermocouples only produce millivolts of voltage.
You should be able to put a connector in series with the thermocouple as long as the connector doesn't add any resistance. It's only the tip of the thermocouple which produces the voltage. If you jiggle (official EE term) the connector while running does the gauge move around? |
VaccaRabite |
Oct 11 2023, 07:50 AM
I'm guessing you didn't have a setup similar to the dakota digital? That thermocoupler has disconnects already built in. With that in mind I'm surprised your setup would be much different. I don't know much about the inner workings of thermo dynamics just that heat is transferred via these two wires to the gauge. I guess if the metals were dissimilar in your connection points that would cause a discrepancy. Good to know though about other types of CHTs. It is a Dakota Digital actually. But the screws are under the tins. In the past I've always just fished everything out after pulling the #3 spark plug. The thermocouples only produce millivolts of voltage. You should be able to put a connector in series with the thermocouple as long as the connector doesn't add any resistance. It's only the tip of the thermocouple which produces the voltage. If you jiggle (official EE term) the connector while running does the gauge move around? I'll have to see. Easy enough test to do tonight after work. Driving over bumpy roads though did not seem to have an effect. Zach |
76-914 |
Oct 11 2023, 08:13 AM
We just temperature tested a unit we're designing using 7 thermocouples. The logging device we connected to just had terminals with screws to attach the thermocouples. The thermocouples only produce millivolts of voltage. You should be able to put a connector in series with the thermocouple as long as the connector doesn't add any resistance. It's only the tip of the thermocouple which produces the voltage. If you jiggle (official EE term) the connector while running does the gauge move around? This was the first thing that crossed my mind. I would think this is what happened. Spoke, please publish your report on the accuracy of those senders. I tested the Dakota vs. the VDO years ago and found the Dakota to be very accurate and the VDO not. I had suspected the VDO gauge but as it turned out the VDO gauge performed well when coupled, no pun intended, to the Dakota sender. |
emerygt350 |
Oct 11 2023, 08:30 AM
Advanced Member Group: Members Posts: 2,096 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I have the DD as well, and I swear they had a little note with it about cutting the cable, as in you could but there was something about not increasing the length I think.
Superhawk996 |
Oct 11 2023, 09:22 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Free white paper for the day:
Cylinder head temp gauges are just a thermocouple gauge designed to read a specific type thermocouple. There are many different types of thermocouples available depending on what type of wire is used in its construction and what temperature range is being measured. Dakota Digital uses K-type based on images of their sender and extension wire that I see online. In K Type Thermocouple positive leg is composed of 90% nickel, 10%chromium and a negative leg is composed of 95% nickel, 2% aluminum, 2% manganese and 1% silicon. These are the most common general purpose thermocouple with a sensitivity of approx 41µV/°C. https://tempsens.com/blog/k-type-thermocouple Each type of thermocouple can be identified by its wire colors. There are two different types of K-type wire that can be used to route to the gauge. 1) Thermocouple Grade wire -- this can be used to make the sensing end and could be used all the way to the gauge -- but it is more expensive wire so it is rarely used all the way to the gauge. Thermocouple grade wire has a brown exterior insulation and for K-type the internal wires will be red (actually the negative wire -- UGH!) and a yellow wire (the positive wire) 2) Thermocouple Extension Grade wire -- this cannot be used to make the sensing end of the cable. Extension Grade wire can only be used to extend the sensor to the gauge or data acquisition rig. It's wire is made of material that closely mimics the sensing wire but is not exactly the same. It is however, vastly different than copper wire. K-type Extension Grade wire will have a yellow exterior insulation. The internal conductors will be red and yellow. Note: There are exceptions (aren't there always). The thermocouple wire can be obtained as single strands - without an exterior insulation holding both together. And if I recall my old VDO - it had wires that were covered with a braided material and had a non-standard color code. Likewise there are huge color code variations between the US and Europe regarding color coding and identification of wire type. If you look online you can find identification charts that cover all the wire types, as well as the US and International color coding. Thermocouple extensions can be spliced. However, they are spliced with a connector that mimics the behavior of the thermocouple sensing end and the extension cable. The connectors are specific to the type of thermocouple wire that is used for the senor / extension cable. Here is an example of a K-type connector https://www.farnell.com/datasheets/2339540.pdf There are several different styles and sizes of connectors but each has to be matched to the thermocouple wire type. Moral of the story: If you replace your standard wiring connector (copper / tin terminals) with the proper K-type thermocouple connector, you'll be back to a fully operational system and won't have to rewire the whole thing all the way back into the cabin. |
stownsen914 |
Oct 11 2023, 11:46 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
What type of connector did you use? Since thermocouples/CHT setups are sensitive to small changes in resistance, you might just need to use a high quality connector like a Deutsch that's intended to minimize such issues. One of my cars has an old school EGT which uses thermocouples, and it's set up with Omega connectors that are intended for thermocouples like these.
Shivers |
Oct 11 2023, 01:29 PM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
https://www.amazon.com/T-Type-Thermocouple-...66697&psc=1
This type might work. Give a call when you know the specs on the TC you have. They may have just what you need. |
Superhawk996 |
Oct 11 2023, 02:51 PM
Verify you have K-type (red and yellow conductors). If that is indeed what you have, I just went though my stash and I have a K-type connector pair (male and female) I will send for free if you want to repair what you have.
FYI - you can also buy silicone boots that will go over the thermocouple connectors to make them more weatherproof but I don't have any of those. Deutsch (some styles) connectors can be ordered with special pins to accommodate the special conductors needed for thermocouples. Think $20 per pin. Standard Deutsch automotive connectors are not going to work as they are still copper pins. |
Oct 11 2023, 06:28 PM
We thank you |
iankarr |
Oct 11 2023, 11:00 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Question…if the ends of that red/yellow extension wire were flipped, what would that do to the readings?
ogdougy |
Oct 11 2023, 11:34 PM
Newbie Group: Members Posts: 49 Joined: 9-May 22 From: Arizona Member No.: 26,536 Region Association: Southwest Region |
If you accidentally flipped the wires of a thermocouple . The readings will just go opposite. When it gets hotter it will read out a colder number, thats all.
The IC for a thermocouple is just an differential op amp (with some other things like cold junction compensation). All it does is take the voltages from the two wires, subtract them, and then amplify a signal to a readable output. No damage |
VaccaRabite |
Oct 12 2023, 07:41 AM
Verify you have K-type (red and yellow conductors). If that is indeed what you have, I just went though my stash and I have a K-type connector pair (male and female) I will send for free if you want to repair what you have. FYI - you can also buy silicone boots that will go over the thermocouple connectors to make them more weatherproof but I don't have any of those. Deutsch (some styles) connectors can be ordered with special pins to accommodate the special conductors needed for thermocouples. Think $20 per pin. Standard Deutsch automotive connectors are not going to work as they are still copper pins. Yes, its a K type thermocouple. and Thank You! Zach |
barefoot |
Oct 12 2023, 10:08 AM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Here's what I used, extension is long enough to route thru center tunnel up to under dash gauge. A very cheap solution.
https://www.ebay.com/itm/203517821362 |
914_teener |
Oct 12 2023, 01:30 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Saying of the Day:
"Do or Not Do, There is no try" ---Yoda |
Geezer914 |
Oct 12 2023, 03:52 PM
Geezer914 Group: Members Posts: 1,412 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Here's what I used, extension is long enough to route thru center tunnel up to under dash gauge. A very cheap solution. https://www.ebay.com/itm/203517821362 Did this work with a Dakota Digital gauge? |
stownsen914 |
Oct 12 2023, 10:28 PM
Shivers |
Oct 12 2023, 10:40 PM
Here's what I used, extension is long enough to route thru center tunnel up to under dash gauge. A very cheap solution. https://www.ebay.com/itm/203517821362 Did this work with a Dakota Digital gauge? Went and looked at the ad. It says: Type Ungrounded K Type Thermocouple So if you look up your gauge it should say what type of TC you need. I think it will work with the VDO. |
stownsen914 |
Oct 12 2023, 10:43 PM
Well I asked the vendor and got this response:
Yes, the VDO CHT gauge normally use K type thermocouple as input and it is fully compatible with our sender. Please make sure that the yellow wire is connected to the positive and the red wire is connected to the negative. It should work. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:56 PM |
