> How common is the clutch cable becoming the ground?, My present clutch cable malady may be this issue....
second wind
post Nov 16 2023, 10:50 PM
Hello all....I have been tackling a clutch cable problem and finally closing in on a solution....but my existing failed cable is so stubborn upon removal that it seems that the inner cable is welded to the outer housing....I have heard about the clutch cable becoming the ground for the car and I wonder how often this occurs and what are the symptoms?? I would like to prevent this from occurring while I am in clutch cable repair mode....thank you very much!!
gg
Dave_Darling
post Nov 17 2023, 12:24 AM
914 Idiot
Yup, it usually doesn't provide a ground unless the regular chassis grounds are f***ed. Say, if someone doesn't remember to reconnect the transmission ground strap. Or there's significant corrosion in the strap or the grounding stud.
--DD
- Lo-Fi Version Time is now: 16th November 2025 - 03:08 AM
