| second wind |
Nov 16 2023, 10:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California
Hello all....I have been tackling a clutch cable problem and finally closing in on a solution....but my existing failed cable is so stubborn upon removal that it seems that the inner cable is welded to the outer housing....I have heard about the clutch cable becoming the ground for the car and I wonder how often this occurs and what are the symptoms?? I would like to prevent this from occurring while I am in clutch cable repair mode....thank you very much!!
gg |
| Mikey914 |
Nov 17 2023, 01:20 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,777 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Common, it happened to me. Just make sure your ground strap is making good contact, and replace it if it looks crappy.
Easy simple solution that should be part of your spring ritual to check before the drive season. |
second wind How common is the clutch cable becoming the ground? Nov 16 2023, 10:50 PM
yellowporky Make sure the trans to body ground is clean and go... Nov 16 2023, 11:45 PM
Dave_Darling Yup, it usually doesn't provide a ground unles... Nov 17 2023, 12:24 AM
dr914@autoatlanta.com I was very good at replacing the clutch assembly i... Nov 17 2023, 01:46 PM
worn
I was very good at replacing the clutch assembly ... Nov 19 2023, 06:06 PM
second wind Thank you all...it is all making sense to me....my... Nov 17 2023, 04:06 PM
technicalninja I'm a huge believer in excess grounds.
I... Nov 17 2023, 04:16 PM
Superhawk996
Lots of cars have extra ground cables to the hood... Nov 17 2023, 04:29 PM
second wind Thank you all....so is there a way to test the gro... Nov 19 2023, 11:23 AM
Superhawk996
Thank you all....so is there a way to test the gr... Nov 19 2023, 11:46 AM
mb911 I think along with hood straps the metal that it a... Nov 19 2023, 01:14 PM
second wind Hello fellow clutch cable grounders.....do you thi... Nov 24 2023, 12:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 06:11 AM |
