> How common is the clutch cable becoming the ground?, My present clutch cable malady may be this issue....
second wind
post Nov 16 2023, 10:50 PM
Hello all....I have been tackling a clutch cable problem and finally closing in on a solution....but my existing failed cable is so stubborn upon removal that it seems that the inner cable is welded to the outer housing....I have heard about the clutch cable becoming the ground for the car and I wonder how often this occurs and what are the symptoms?? I would like to prevent this from occurring while I am in clutch cable repair mode....thank you very much!!
gg
second wind
post Nov 19 2023, 11:23 AM
Thank you all....so is there a way to test the ground strap to see if it is any good? What makes it deteriorate anyway? Why and how does this negative phenomenon occur anyhow? Thank you again...
gg
- Lo-Fi Version Time is now: 10th May 2026 - 05:43 AM
