Front Suspension Questions, Tie Rod Starting Length, Powder Coating Struts |
DennisV |
Nov 19 2023, 02:19 PM
Member Group: Members Posts: 468 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
A couple front suspension questions. Working on 1970 914-6 if it matters.
1. What would be a good starting length for tie rods? I took a rough measurement of ours when I removed them, but I think something is not correct. Left to right was not even close to the same length. The number of threads visible on inner and outer tie rod ends weren't close to the same either. 2. Is there any reason I shouldn't have the struts powder coated? Minus the spindle of course. Most of the paint is gone off of ours. Though I can see a couple place where they were originally gray. |
Shivers |
Nov 19 2023, 02:31 PM
Senior Member Group: Members Posts: 2,381 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
If you still have the original rods, you can measure those. That is what I did. There are others here that have posted pics of powder coated struts.
bdstone914 |
Nov 19 2023, 04:37 PM
Yes you can powder coat the struts. Also mask the holes for the ball joint and pinch bolt and strut insert cap. Clean tbe strut inside before powder coating.
Only reason to not powder coat if you are concerned about oroginality. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:50 PM |
