35 Pages V « < 24 25 26 27 28 > »
> Fred's Backyard LE Restoration
friethmiller
post May 28 2025, 07:54 AM
Post #501
Driver Side Door - Part 2 (5/27/2025):
Starting in on the back side of the door. First up is removing the hinges. I like removing these, if for nothing else, in order to knock off 50 years of rust and grime. A small amount of grease would go a long way too. Photos show the use of a MAPP torch and a punch to remove the hinge pins.
Next, I'm diving straight into removing part of the door. For this one, I thought I try removing the bottom section. I did this on my previous 914 and it worked out well. No right answer here. It's just a matter of getting access inside the door. My thinking was that with the dents in the bottom half, I might get in behind some of the support structures to pound out a few of these low spots. Here I've made three main cuts - avoiding any recesses in the door structure. Final cut was down about 90% of the door edge. This metal is crusty and needs to be replaced just like the other door.
Looking inside you can see the rust. Not too bad but it needs to be removed. Here you can see at least 4 spots where somebody has done some heat-shrinking on the bottom half of this door. Not a bad thing. I guess the dents must have been much worse. You may notice that I screwed up and cut over a little too far on one side. Clipped off the edge of an internal structure. I'll will fix this prior to reassembly.
After flipping the door over, I was able to get one of my flappers in between the support and one of the low areas to work as a dolly. I could now push up from below and slap the surrounding highs to bring out a lot of this initial dent. After finding a marker, I continued a bit to see how the metal on this lower half of the door looked. Not bad if you ask me. I was able to get a good bit out and identify areas that need additional work. Going to get all my body tools out next and see what I can do. Stay tuned...
Puebloswatcop
post May 28 2025, 08:21 AM
Post #502
Looking good Fred. I love to watch you work and seeing the progress.
friethmiller
post May 28 2025, 10:57 AM
Post #503
QUOTE(Puebloswatcop @ May 28 2025, 09:21 AM) *
Thanks Kevin. I see we're both doing doors at the same time. Good luck with yours (IMG:style_emoticons/default/beer.gif)
bkrantz
post May 28 2025, 08:30 PM
Post #504
Nice.
I never had enough patience to keep slapping until the metal was straight enough to avoid a skim coat of bondo, but getting the shape within 98% is a worthy goal.
friethmiller
post May 29 2025, 07:48 AM
Post #505
QUOTE(bkrantz @ May 28 2025, 09:30 PM) *
Nice.
(IMG:style_emoticons/default/agree.gif) Based on the amount of bondo that was on the panel (see photos), I think we are good for a bit of "slapp'n". A skim coat of bondo is fine with me. Let's make it the goal here.
gereed75
post May 29 2025, 08:59 AM
Post #506
I have a cheap small 4 1/2 shrinking disc that I use on a 4” grinder that works fantastic on this kind of stuff. 10 seconds or so followed by a quick water squirt takes those local highs out quickly and tightens the panel - like magic!!
friethmiller
post May 29 2025, 10:39 AM
Post #507
QUOTE(gereed75 @ May 29 2025, 09:59 AM) *
Yes! That's the plan. I've got everything ready to go - just waiting on all this rainy weather to clear.
930cabman
post May 30 2025, 04:40 PM
Post #508
QUOTE(friethmiller @ May 29 2025, 10:39 AM) *
something new to me, would a torch get the same result? excuse my ignorance
friethmiller
post Jun 1 2025, 07:37 PM
Post #509
QUOTE(930cabman @ May 30 2025, 05:40 PM) *
Sure, but I think the torch is better for bigger stuff. The disc is really good as you get things closer. You'll see shortly what I had to do on mine this weekend. Currently uploading photos. (IMG:style_emoticons/default/type.gif)
friethmiller
post Jun 1 2025, 08:39 PM
Post #510
Driver Side Door - Part 3 (5/31/2025):
Saturday was the day that I had set aside to finish straightening out this door panel. However, the backing pad that went behind the shrinking disc on my grinder, that I had ordered, did not arrive in time. I attempted to use the disc without it but the grinder's nut was proud of the disc which only allowed the outer edge of the disc to make contact with the door metal. The result was insufficient friction so I was unable to heat the metal to the required temperatures. Instead, I was forced to use a hammer & dolly. However, I did use my torch to heat up the largest dent in the panel and lever it up with my large slapper from behind. Previous metal work done years ago attempted to do this but with all the support structure in these later doors, you just can’t get in behind a lot of these dents. The only reason, I had better access was the fact that I cut out the bottom half of the inner door. The first photo here shows the low areas I attacked first. The top low was the largest and this was later heated & and pushed up. The rest of the photos here show my work down the panel. It may be hard to tell but the lower section of this door is much better than before - see final photo. While not perfect, it will require a lot less filler to straighten out. After all this work, the door was cleaned again and the metal re-etched.
Note the extreme scratches left by the previous work. Another reason to use filler here.
Next, Glass-blasting! My least favorate thing to do on a warm sunny Texas day. Placed a tarp down and went after it. Goal was to get the hard to reach areas on the inside front and back sides, followed by the inside of the door itself. In the end I was covered with glass, sweaty, and glad to be done with all that. Goal was to get the majority of the heavy rust that was inside the door. I will be using Rust Bullet epoxy to seal everything at the end. Here are two photos of the blasting process.
Blasting exposed two drill holes that had been filled with puddy. Fixed them by zapping them closed using a copper backer.
Final job of the day was to clean and paint the inside with the first coat of epoxy. This messy job was applied using a small paint brush. I plan to do the final coat once the door is welded back together. Tomorrow will be a lot of fiddly patches and reassembly of the lower door section. Stay tuned...
Dion
post Jun 2 2025, 05:21 AM
Post #511
RN
Fred…. Wow, just wow. That is a lot of work. Patience for sure.
Outstanding stuff. Appreciate your documentation.
Door are going to be the best around.
friethmiller
post Jun 2 2025, 07:36 AM
Post #512
QUOTE(Dion @ Jun 2 2025, 06:21 AM) *
Ha! I'm just working my way through my to-do list here. Getting ready to post my work from yesterday [very soon]. Looks like it's going to take an additional day or two to get this door completed. That'll make it three weekends per door. Wow! (IMG:style_emoticons/default/blink.gif)
friethmiller
post Jun 2 2025, 08:20 AM
Post #513
Driver Side Door - Part 4 (6/1/2025):
Started my Sunday morning off by separating the inner door seal from the bottom edge of the door skin. This took a bit of time but the two pieces eventually separated. After that, I made templates for a bunch of little patches that I'll needed to do.
Patch #1
Here I'm fixing the first half of the hole in the bottom of the inner door. This is the spot where most doors rust-out. Note: Patch #3 is the second half of this spot. This repair wasn't my best but I will make time later to clean it up - once everything is reassembled.
Patch #2
This is a small spot in the seal track about mid-way down the door. Simple/straight ahead repair here but done from the backside. Last photo shows the [weld] bleed-through into the seal track.
Patch #3
This is the other half of patch #1 but the repair was a bit more difficult. Access to the back wasn't even possible and the seal track prevents good welder positioning on about half of this patch. She's just ugly! But, again, we'll clean it up later.
Patch #4
This is a small repair to the seal track adjacent to the door track (thingy). Pretty easy.
Patch #5
Repair to the same seal track just under the top of the door. This was another easy repair.
Mirror Hole Repair
Another door, another set of after-market mirror holes to fill (IMG:style_emoticons/default/rolleyes.gif)
Inner Door Seal Track Replacement
At this point I was finally able to get down to business with some larger structural fixes. Here I'm templating out two pieces that will replace the rusted edge of metal that I exposed earlier in the morning. You might notice that I am saving the three original inlets that allow the door to drain. This made the patch tricky to form and fit up but in the end retains the drains in their original configuration. The following photos show the repair that took about 3 hours to complete.
Reassembling the Door Bottom
After grinding down all the welds down the length of the inner door repair, I was ready to re-weld the door. It was already pushing 5pm at this point so I decided to finish most of the welding and just call it a day. More to come in Part 5, I guess. Cheers (IMG:style_emoticons/default/beerchug.gif)
930cabman
post Jun 2 2025, 05:23 PM
Post #514
I need to remove a section of the door bottom from my drivers door, but wish I had the time and talent of Fred.
Go Fred Go
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
friethmiller
post Jun 3 2025, 07:43 AM
Post #515
QUOTE(930cabman @ Jun 2 2025, 06:23 PM) *
Go Fred Go
I humbly submit... I'm making it up as I go along here. Just enjoying the process. (IMG:style_emoticons/default/welder.gif)
bkrantz
post Jun 3 2025, 07:31 PM
Post #516
QUOTE(friethmiller @ Jun 3 2025, 06:43 AM) *
Go Fred Go
I always felt my over-confidence and naive optimism makes up for lack of expertise.
friethmiller
post Jun 3 2025, 09:06 PM
Post #517
QUOTE(bkrantz @ Jun 3 2025, 08:31 PM) *
Right on! (IMG:style_emoticons/default/beerchug.gif)
930cabman
post Jun 4 2025, 04:47 AM
Post #518
QUOTE(bkrantz @ Jun 3 2025, 07:31 PM) *
Go Fred Go
or, I can mess up as good as the next guy
Puebloswatcop
post Jun 6 2025, 01:55 PM
Post #519
Hey Fred is it as hot and humid over there as it is here? If it is are you still working on the car in this misery? If so, be careful stay hydrated ansd take long breaks. As always love the work you are doing. (IMG:style_emoticons/default/beerchug.gif)
friethmiller
post Jun 6 2025, 08:10 PM
Post #520
Yep! Hydration is key! I’ll be out on the LE in the morning - packing a cooler for sure!
BTW, Got the new bottom edge installed and welded in-place this evening. I have to address one area that’s oil-canning pretty bad (marker spot)
- Lo-Fi Version Time is now: 10th November 2025 - 07:57 PM
