39 Pages V « < 28 29 30 31 32 > »
> Fred's Backyard LE Restoration
friethmiller
post Aug 14 2025, 08:42 AM
Post #581
Front LE Valance - Part 1 (8/10 - 8/13/2025)
Knowing this valance would take a lot of time, I got underway on its restoration starting Monday evening. Here are a few photos of the progress to-date. It's going to get ugly here so hang on. First task was to finish all the plastic welding that I had done about a year ago just to hold the parts together. This ended up helping me out a lot since I didn't have to puzzle-piece anything together.
Next, using a bulb grinder bit I hollowed out all the major cracks on either end of the part from the front. This worked very well. Note the metal "floss" sticking through from the plastic welds.
Next, in order to bond the cracks I used JB Weld's 2-part epoxy resin glue. Mixed a few batches and used a popsicle stick to make sure all the cracks got filled. Just like pre-school art here!
After all that dried, I went in and started the process by replacing two missing sections at the bottom-center of the valance. This is a very critical spot that, when repaired, will give back a lot of the rigidity to the part. To do this, I used cardboard as my form. I simply taped it in to provide just a bit of backing support for the fiberglass. With this done, I then mixed up the resin and layered in several pieces from the front. Note in the 3rd photo how I trimmed back the extra fiberglass. First with scissors and then with the grinder with a flip disk. Last photo shows the results of most of the cardboard and tape removed - showing just this outside layer applied/hardened.
Next up is the application of addition glass to the backside of the repair. I also took the opportunity to cover the plastic welded areas with 2x sheets of glass to provide additional strength to these areas.
After letting all this dry overnight, I will trim every up and continue with additional repairs that are necessary for this valance. More to come soon... Cheers! (IMG:style_emoticons/default/beerchug.gif)
Root_Werks
post Aug 14 2025, 10:53 AM
Post #582
Village Idiot
If that's an original LE front valiance, worth every effort to repair it. If it's replacement fiberglass, hard to believe they are $400, yikes!
Puebloswatcop
post Aug 14 2025, 12:20 PM
Post #583
You are moving swiftly on it Fred (IMG:style_emoticons/default/smash.gif) . Don't build too fast, or you won't have anything to keep you out of trouble. (IMG:style_emoticons/default/beerchug.gif)
friethmiller
post Aug 14 2025, 12:28 PM
Post #584
It's hard to believe!
This isn't an original LE valance that I'm working on here but a vintage OEM replacement. It isn't worth saving on it's own. I'm just unwilling to pony-up 400 clams for this part. I'm also worried that the AA part, while cheaper, won't be the same quality.
It's too late at this point anyways... I'm committed (IMG:style_emoticons/default/screwy.gif)
friethmiller
post Aug 17 2025, 11:39 AM
Post #585
Front LE Valance - Part 2 (8/16/2025)
On Saturday, I started from a point where the epoxy glue had been sanded down and the panel cleaned. From here... many iterations of body filler & hand sanding with blocks (soft and semi-soft).
Once satisfied that I was getting close, I mounted the spoiler to check gaps and see how the wheel arches looked. These non-factory panels tend to have some weird forward sweeping ends that I was going to try and fix. Using washers to simulate the thick rubber spacers (which are on order), I had a look at the backend of the spoiler. Not great. You can see by the last set of photos what I'm shooting for, approximately. I used cardboard to help mock up where I wanted the new edges to be.
Once the valance was removed, I then trimmed the cardboard and taped it onto the panel from the backside. Next, it was a couple of layers of fiberglass put down from the front. After drying, most of the cardboard was removed and glass was placed on the backside. Once this was dry, I then trimmed back the excess fiberglass and used 3M Fiberglass filler to fill and help strengthen the ends. Love this stuff! It's super strong but hard to sand! You need 40 to 80 grit, to get any where with it. Here are some photos of the process. Sunday will be painting and mounting this panel.
friethmiller
post Aug 17 2025, 11:59 AM
Post #586
Front LE Valance - Part 3 (8/17/2025)
I had the paint ready this morning at sunrise. (IMG:style_emoticons/default/smile.gif) After hitting the spoiler with 2 coats of gray epoxy, I let it dry for a few hours. I then came out and mounted the panel on the car with the new mounting hardware [that I had bagged from the previous day]. Here's a quick set of photos showing the rebuilt spoiler + other shots. While it still needs additional bodywork and finer sanding, I think I call it restored.
Next up, bumpers!! (IMG:style_emoticons/default/bootyshake.gif)
slowrodent
post Aug 17 2025, 12:26 PM
Post #587
Very very nice job on the glass repair! (IMG:style_emoticons/default/smile.gif)
trojanhorsepower
post Aug 17 2025, 01:40 PM
Post #588
Looks great. Looking for ward to seeing how you deal with the bumpers.
Montreal914
post Aug 17 2025, 02:19 PM
Post #589
Very nice job on the LE replica valance. (IMG:style_emoticons/default/smilie_pokal.gif)
While you are working on the ends, ever though of adding those dowel shaped reinforcement à la real LE valance? (IMG:style_emoticons/default/idea.gif)
Phote courtesy of Jeff Bowlsby's website:
East coaster
post Aug 17 2025, 02:52 PM
Post #590
I’m confused by the plastic welding portion. Isn’t it a fiberglass part?
friethmiller
post Aug 17 2025, 03:58 PM
Post #591
QUOTE(East coaster @ Aug 17 2025, 03:52 PM) *
Perhaps @JeffBowlsby knows more about it but this vintage part is some sort of plastic - not fiberglass. I just added some for this repair, of course.
friethmiller
post Aug 17 2025, 04:05 PM
Post #592
QUOTE(Montreal914 @ Aug 17 2025, 03:19 PM) *
Yeah, I thought about doing that but it's not anything close to the original in shape. I may, however, close the ends with a vertical piece. It looked like it once had closed off ends. Not sure. It's more work but I think it would look more finished.
friethmiller
post Aug 17 2025, 04:20 PM
Post #593
QUOTE(slowrodent @ Aug 17 2025, 01:26 PM) *
QUOTE(trojanhorsepower @ Aug 17 2025, 02:40 PM) *
Thanks guys! Front bumper has a good bit of damage in the middle - just removed a lot of bondo (1/2 inch thick in places), this afternoon. In progress on the rear bumper. It has damage on the left rear, as well. It's not as bad but more bondo. Going to need to get out the BFH and a dolly (IMG:style_emoticons/default/biggrin.gif)
Montreal914
post Aug 17 2025, 06:43 PM
Post #594
QUOTE(friethmiller @ Aug 17 2025, 03:05 PM) *
My replica folds in on its ends for a thicker/sturdier look. Unfortunately it's in the rafters so I can't take pictures...
friethmiller
post Aug 17 2025, 07:05 PM
Post #595
QUOTE(Montreal914 @ Aug 17 2025, 07:43 PM) *
No worries! I'll see about adding them when I get a chance.
friethmiller
post Aug 17 2025, 07:16 PM
Post #596
Bonus Photos
Better lighting and larger photos so you can see the less-than-perfect body work. Definitely needs some additional blocking with finer grit sandpaper.
JeffBowlsby
post Aug 17 2025, 09:07 PM
Post #597
QUOTE(friethmiller @ Aug 17 2025, 02:58 PM) *
I was told by a plastics specialist who examined my original factory spoiler that it is fabricated using molding dough compound. MDC is (or was) used prolifically in the automotive industry for fast, high volume parts. It’s a process that uses a two part mold, heat and compression to make the part. Epoxy/fiberglass is compatible with MDC.
JeffBowlsby
Post #598
friethmiller
post Aug 18 2025, 08:04 AM
Post #599
QUOTE(JeffBowlsby @ Aug 17 2025, 10:07 PM) *
Thanks Jeff! This stuff was definitely not fiberglass. The spoiler had been repaired before so no telling how old it actually is. Glad it will live on for a little while longer (IMG:style_emoticons/default/driving.gif)
friethmiller
post Aug 31 2025, 08:03 AM
Post #600
Bumper Restoration - Part 1 (8/16 - 8/17/2025)
Review
These bumpers have seen better days - no doubt. Before even starting on them I could see that the paint and bono was thick with a lot of spider cracking over most of the surface. Rust seemed to be accident-related. Arrows show the damage and heavy bondo areas.
Reveal
Getting to work on the front bumper, the paint-removing disk shows just how much filler was involved. After the dust cloud settled the primary damage was in the center of the bumper. Cleaning up the backside a bit revealed just how much hammering somebody had done before. Last photo shows the filler and the 10 layers of paint present. No wonder there were cracks. In the end, the rear bumper was in pretty good shape. The front was another matter.
Hammer and Dolly Time
While I couldn't get to everything, I could certainly get a lot of the damage hammered out. Using a large marker and a flexible block with 80-grit sandpaper, I was able to quickly identify all the low spots in the bumper. By holding the dolly on the front over the low spot, I used my body hammer to work the lows back inline. This process went on for many hours over the next couple of days. Final photo show a low section on the end of the bumper that was directly in front of the main bumper mounting bracket on the backside. I was only able to get out so much of these dents - so filler will need to be reapplied. In the end, I was actually pretty happy with the results. It will take much less filler to flatten this bumper.
Rust-Prevention
After deciding not to sandblast these fine specimens, I pulled out the Rust Bullet, prep'd the bumpers, and then painted 2x coats on the backside. I also did the same for the pitted areas on the front bumper. Note: the phosphorus-based prep done prior to painting cleaned off all the remaining black marker. Windex and Wax & Grease Remover won't remove it.
Epoxy Primer
Had to use black epoxy here, since I was out of gray. I will hit this with gray later after filler has been applied.
- Lo-Fi Version Time is now: 10th January 2026 - 02:48 PM
