Right wing mirror, Fitting |
porschenstock |
Dec 14 2023, 02:26 AM
Newbie Group: Members Posts: 24 Joined: 14-April 08 From: ca Member No.: 8,921 Region Association: None |
Hi All,
I have bought a wing mirror to fit on the right of my 914, anyone has the right original position to place it before I drill the holes on my right door. Many thanks. |
dax1969 |
Dec 14 2023, 03:30 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Remove door panel and you will see welded in bracket/bolts. Use punch to mark where you need to drill. hope it helps rgds Dax |
porschenstock |
Dec 15 2023, 04:09 AM
Remove door panel and you will see welded in bracket/bolts. Use punch to mark where you need to drill. hope it helps rgds Dax Hi Dax, Many thanks, I will get the panel off, useful on tracks (IMG:style_emoticons/default/smile.gif) Chris |
Lo-Fi Version | Time is now: 14th May 2024 - 10:50 AM |
