OT.Don't put DEF in your diesel's fuel tank |
technicalninja |
Dec 15 2023, 04:02 PM
Senior Member Group: Members Posts: 1,273 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
This has NOTHING to do with Porsches...
One of my close friends (3 decades customer/friend who does my Website) screwed up yesterday and put 12 gallons of DEF fluid on top of 10 gallons of diesel in his 2021 Chevrolet Duramax 3/4 ton truck... He showed extreme foresight in calling me BEFORE he tried to start it again. I said NO and we had it towed in on a flatbed wrecker. I'm going to be able to save it inexpensively, but I started a conversation with a long-term parts guy at the Chevrolet dealer that startled me enough to say "Wow, maybe I should post this." Had Len started it, it would most likely need an ENTIRE fuel system. 10K... Had he run it down the road it would need the above AND a new engine!!!!!! 30K more! He called Chevrolet Service first as I am "On Vacation" and my shop is closed to new work till February. He changed the website to reflect this so he did not think I would want to play with his screw-up. The dealer was ESTATIC to get the truck in! This type of damage is often covered under the comprehensive portion of the vehicle's insurance. I believe most dealers would find "needs entire fuel system" with no damage and the owner would have to pay a deducible and be without truck for XX days... We're going to drain/clean tank and maybe replace the in-tank "sending unit" which I believe is a low-pressure transfer pump. It will get a new fuel filter now and another 2-3 tanks of fuel in the future. Total cost should be less than $300 but I get to deal with 25 gallons of SLIME, the shop will stink for 2 days, and I'm having to come off of vacation to work on BIG ASSED domestic truck which I detest! Len is "family" and I'm screwed... Moral of this story: Be insanely careful with adding DEF to your diesel. They made the DEF fill hole and nozzle SMALLER so you couldn't put diesel into the DEF tank. It's looking like the reverse might actually be worse... |
Jamie |
Dec 15 2023, 04:57 PM
Senior Member Group: Members Posts: 1,033 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
This has NOTHING to do with Porsches... One of my close friends (3 decades customer/friend who does my Website) screwed up yesterday and put 12 gallons of DEF fluid on top of 10 gallons of diesel in his 2021 Chevrolet Duramax 3/4 ton truck... He showed extreme foresight in calling me BEFORE he tried to start it again. I said NO and we had it towed in on a flatbed wrecker. I'm going to be able to save it inexpensively, but I started a conversation with a long-term parts guy at the Chevrolet dealer that startled me enough to say "Wow, maybe I should post this." Had Len started it, it would most likely need an ENTIRE fuel system. 10K... Had he run it down the road it would need the above AND a new engine!!!!!! 30K more! He called Chevrolet Service first as I am "On Vacation" and my shop is closed to new work till February. He changed the website to reflect this so he did not think I would want to play with his screw-up. The dealer was ESTATIC to get the truck in! This type of damage is often covered under the comprehensive portion of the vehicle's insurance. I believe most dealers would find "needs entire fuel system" with no damage and the owner would have to pay a deducible and be without truck for XX days... We're going to drain/clean tank and maybe replace the in-tank "sending unit" which I believe is a low-pressure transfer pump. It will get a new fuel filter now and another 2-3 tanks of fuel in the future. Total cost should be less than $300 but I get to deal with 25 gallons of SLIME, the shop will stink for 2 days, and I'm having to come off of vacation to work on BIG ASSED domestic truck which I detest! Len is "family" and I'm screwed... Moral of this story: Be insanely careful with adding DEF to your diesel. They made the DEF fill hole and nozzle SMALLER so you couldn't put diesel into the DEF tank. It's looking like the reverse might actually be worse... How could that happen, are the fillers close to each other? (IMG:style_emoticons/default/shades.gif) |
technicalninja |
Dec 15 2023, 05:19 PM
The DEF fill port is 3" away from the fuel fill port...
The DEF port is 1/2 the diameter of the fuel port. |
brant |
Dec 15 2023, 05:27 PM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I purpose bought a used Cummins that was pre DEF to tow my 914 to avoid this kinda crap
Shivers |
Dec 15 2023, 05:42 PM
Senior Member Group: Members Posts: 2,407 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I purpose bought a used Cummins that was pre DEF to tow my 914 to avoid this kinda crap I was going to make a joke about it being more like pee. I have an 85 ford with the IH 6.9 L diesel. I had heard about some fluid they had to add now but didn’t know what it was called. I had to look up DEF and was really surprised what it was. Synthetic piss in water. Love to know whose idea that was. Thank goodness you were able to save it |
porschetub |
Dec 15 2023, 06:44 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Whats a DEF ? thanks.
technicalninja |
Dec 15 2023, 07:22 PM
DEF is 33% urea (the base of urine) and 67% water.
It is injected into the exhaust system pre DPF (diesel particulate filter) to break down the diesel particulates so that they will "burn" into ash. This ash is RETAINED in the DPH until it is full at which point the DPF should be replaced. Lots of places clean this ash from DPF (for a fee) making them somewhat re-usable. DPFs can cost up to 5K!!!!! Diesels stopped visibly smoking in 2007 because of an ENTIRE slew of emission devices that were required by law... They got EGRs at the same time and the EGRs required cooling via a heat exchanger that is plumbed into the vehicles cooling system. They went "bat-shit" crazy on the level of particulates they would accept. Made diesels substantially more expensive to purchase and maintain. Had another bad aspect regarding all forms of aftermarket tuning... Those STUPID BITCHES who made a modern diesel "roll smoke" pissed the EPA off so badly they are far more likely to come visit your "Tuning shop" to see if you, too are breaking the law. When they start their investigation, you are shut down and no-longer allowed to enter your shop. The investigation always takes some time. 6 weeks is a fast one. 6 months is more common. Cobb tuning (Subie guys) went through one of these. I have been offered multiple tuning opportunities. Managment or ownership. One of my earliest students runs Alamo Autosports. I intentionally chose not to do this for other people's street cars for exactly this reason. I'll stick with my automotive AC business as all I have to do to be legal is not release refrigerants... |
technicalninja |
Dec 15 2023, 07:38 PM
Actually, I'm wrong on why DEF is used and what it's trying to achieve...
Can't say I've ever looked it up. It's injected into the exhaust pre catalytic converter to reduce the level of oxides of nitrogen. The EGR systems were also for this. I've noticed some brands use it and some brands don't. I'll look more closely at Len's truck to see how complex the EGR system is. DEF is used to combat NOX, it is not used to burn the particulates into ash. Some diesels actually inject diesel directly into the exhaust during "re-gen" which is specifically targeted for the particulate/DPF issue. "Re-gen" regenerates the DPF by actual fire in the DPF. I'm NOT a diesel truck mechanic, I despise these things... |
Maltese Falcon |
Dec 15 2023, 07:50 PM
Advanced Member Group: Members Posts: 4,672 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
On our P/U truck the DEF tank will hold approx 5 gal of the fluid; a reminder will appear on the pop-up display when you're low & the remaining miles left until empty. Owners manual* is your friend, as the dealer explained -0- about DEF when we took delivery on the truck. Avail for good prices at Costco in 2.5 gallon jugs,
Dealer/ Steeler prices about twice as much $. * Owners manual suggests not to urinate into the DEF tank (IMG:style_emoticons/default/biggrin.gif) |
Superhawk996 |
Dec 15 2023, 07:59 PM
914 Guru Group: Members Posts: 5,869 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Other things that should be obvious . . .
Don’t put gasoline into a diesel tank Don’t put diesel into a gasoline tank (IMG:style_emoticons/default/lol-2.gif) Amazing that he had the foresight to call and to and the personal integrity to fess up to what happened before it cost him serious money. Now that is a good friend to have!! (IMG:style_emoticons/default/first.gif) Likewise - he’s awfully lucky to have you as a friend that will work on it for him. I hate the smell of diesel and hate working with the stuff . Get it on your hands, clothes, etc., the smell never seems to go away. I hate that the fuel pump areas always look like a Valdez spill occured there since the stuff doesn’t just evaporate. Lord help you if you step in a fresh spill and then get back in your vehicle; getting it on the floor mats. Stinks up the cabin in no time. Unfortunately I have a diesel . . . It’s sort of an experiment despite how much I hate the shortcomings of that fuel. |
76-914 |
Dec 15 2023, 08:13 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I rented a diesel Hyundai in England and the first 3 days I was really impressed by the milage I was getting. It was then that I realized I had been watching the DEF gauge. (IMG:style_emoticons/default/lol-2.gif) I'd never heard of it before that.
technicalninja |
Dec 15 2023, 10:03 PM
Another interesting issue that popped up because of this was the fact that you cannot easily move the shift lever from Park until the engine is actually running.
As this truck was dead-lined for engine start it required "bumping or bouncing" the truck onto the flatbed. This was the first time I've seen this procedure and it really worked quite well. The wrecker driver was able to place the truck at the proper depth centered on my lift. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) The driver also had access to a paid subscription showing drivers how to get vehicles out of park and other needed techniques to tow vehicles. His stuff didn't have any data about a 2-year-old truck... I sometimes have issues with the latest model cars in regard to these things. Getting the ignition fully ON without starting the engine. Smart keys are not real smart! Getting the electronic parking brake to release without engine on and not in park. Getting the transmission out of park not running. These simple tasks have become far more difficult recently with the complete automation of our vehicles. It's a move BACKWARDS in my book. I'll figure out how to release the shift linkage, advise my friend of the procedure. Having a vehicle that you cannot easily make into a roller is a deficiency that might become a serious problem depending on situation. Have a modern vehicle? My advice is to figure out how to clear this hurdle on your car before it is a requirement. |
Shivers |
Dec 15 2023, 10:21 PM
Other things that should be obvious . . . Don’t put gasoline into a diesel tank Don’t put diesel into a gasoline tank (IMG:style_emoticons/default/lol-2.gif) Amazing that he had the foresight to call and to and the personal integrity to fess up to what happened before it cost him serious money. Now that is a good friend to have!! (IMG:style_emoticons/default/first.gif) Likewise - he’s awfully lucky to have you as a friend that will work on it for him. I hate the smell of diesel and hate working with the stuff . Get it on your hands, clothes, etc., the smell never seems to go away. I hate that the fuel pump areas always look like a Valdez spill occured there since the stuff doesn’t just evaporate. Lord help you if you step in a fresh spill and then get back in your vehicle; getting it on the floor mats. Stinks up the cabin in no time. Unfortunately I have a diesel . . . It’s sort of an experiment despite how much I hate the shortcomings of that fuel. In 1985 I learned to love it. I could load two quads and riding stuff in the bed and a fully loaded down 33’ pull behind travel trailer from Los Angeles to Pismo beach at the same speed up hill and down and it never got hot and it never got tired. It’s still around… |
Dec 16 2023, 01:14 AM
It’s sort of an experiment despite how much I hate the shortcomings of that fuel. Diesel also has some benefits. I believe it has a higher energy content than gasoline. On diesel engines, the power output is almost completely controlled by the amount of fuel going in, so there is no throttle to get in the way of your intake air. It also burns down to a very very lean mixture when low power levels are required. These all contribute to it being noticeably more efficient as a motor fuel than gasoline. In the old days, before ultra-low sulfur diesel was the standard, it also required less refining than gasoline. So it was cheaper to purchase, as well as using less. Emissions were rather worse in those days, of course... --DD |
barefoot |
Dec 16 2023, 06:41 AM
Senior Member Group: Members Posts: 1,277 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Other things that should be obvious . . . Don’t put gasoline into a diesel tank Don’t put diesel into a gasoline tank (IMG:style_emoticons/default/lol-2.gif) Unfortunately I have a diesel . . . It’s sort of an experiment despite how much I hate the shortcomings of that fuel. Many yrs ago i had a Diesel VW fastback. One evening I was running VERY low on fuel & some way from home. Only gas station around didn't have diesel so i put 1 gal of gas in and shook the car a bit to try to blend the tank. Got home without any issues. It seemed to run fine. I was lucky. Barefoot |
BillJ |
Dec 16 2023, 07:46 AM
Senior Member Group: Members Posts: 1,098 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
This does have to do with porsches in a way. I had a diesel cayenne for a long time.
jhynesrockmtn |
Dec 16 2023, 09:46 AM
Member Group: Members Posts: 420 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I am always so paranoid when taking my diesel truck to the station for fuel. Convinced I'll someday put gas in it. I hate loaning it to people which doesn't happen often, but occasionally. I'll usually say, please don't fill it with fuel, just let me do it.
Many years ago I was an exec at Gettty Images and had a team in London. The guy running that team was new in the job and from the US. I took one of many trips over there to meet up with him shortly after he got settled. He picked me and another co worker up at the airport. He dropped us at the hotel to drop our luggage off and we were set to go see some sights outside of London. He had a company provided Mercedes wagon. When we got back to the car it wouldn't start. First thing I said was, are you sure it isn't just out of fuel. Yeah, I just filled it up on my way to the airport. I ask, is it gas or diesel? I knew from the look on his face he was clueless being from the US. Huh, why would it be diesel? I said, a lot of cars in Europe are diesel. Sure enough, looked inside the filler cap, it was diesel. That was an expensive lesson for him. |
brant |
Dec 16 2023, 10:12 AM
He didn’t even know after driving it.
Not car smart at all |
Jamie |
Dec 16 2023, 11:49 AM
This does have to do with porsches in a way. I had a diesel cayenne for a long time. And I also love my diesel Cayenne! She's a beast on the road pulling my trailers. (IMG:style_emoticons/default/beer.gif) |
technicalninja |
Dec 16 2023, 07:08 PM
25 gallons in, fuel tank out, transfer pump and sending unit replacement.
Has a roll over valve but we got by it with a piece of 5/16 fuel hose. Old fashion syphoned 23.5 gallons. Took 45 minutes. DEF is heavier than diesel and at one point got 5 gallons of clean DEF out. DEF IS fertilizer, really it is... DEF and diesel separate quickly. My buddy Cory is going to burn the diesel in his shop heater and I'm going to poor the DEF on bare patches of grass here. 100% recycling this crap... Easiest fuel tank pull in 2 decades. NO evap lines at all. Also haven't spilt any yet so the stench is at a minimum... DEF made it to the external fuel filter. Going further upstream to investigate more. Still looks like less than $300 in parts. Looking savable. Gas tank has the NICEST inner lining I've seen yet. Light gray, Super easy to see any debris. Entire inside of tank visible and accessible through FP mount hole. Power to transfer pump is exotic through a fuel pump control module with enough wiring to make me think I'm looking at PWM stuff. Didn't look easy to trick the pump into functioning. Thankfully the syphon worked GREAT! More later Rick |
Lo-Fi Version | Time is now: 28th May 2024 - 06:58 AM |
