Case Through Bolt Washers, Do 914-6 Have Exterior Bevel |
DennisV |
Dec 19 2023, 10:59 PM
Member Group: Members Posts: 473 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Are these correct washers for 914-6 case through bolts? The came off our 1970. As you can probably see, they have a bevel on the interior. The OD is flat on both sides.
When I look up the associated part numbers (901-101-161-01, 901-101-161-02, 901-101-161-03) one side has an exterior bevel. Is this an evolution in design, or do we have the wrong washers? |
DennisV |
Dec 19 2023, 11:17 PM
Wouldn't you know it. Right after posting this I found the answer. According to Bruce Anderson's Porsche 911 Performance Handbook, the washer I have at top was used on early 911 engines up until the 2.7-liter of 1973.
Krieger |
Dec 20 2023, 12:18 AM
Advanced Member Group: Members Posts: 4,721 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
They were on my 78 3.0. The holes on my case where they sit are beveled too. O-rings sit very nicely in the bevel. I have no leaks! anywhere.
rgalla9146 |
Dec 20 2023, 03:01 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Krieger |
Dec 20 2023, 08:40 PM
They were on my 78 3.0. The holes on my case where they sit are beveled too. O-rings sit very nicely in the bevel. I have no leaks! anywhere. Which 'they' were on your '78 911 SC ? The 3.0 engine I have is from a 78 911 SC |
mate914 |
Dec 21 2023, 05:37 AM
Matt Group: Members Posts: 751 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
They were on my 78 3.0. The holes on my case where they sit are beveled too. O-rings sit very nicely in the bevel. I have no leaks! anywhere. Which 'they' were on your '78 911 SC ? The 3.0 engine I have is from a 78 911 SC He was asking witch beveled washers were on your 78 3.0. Matt (IMG:style_emoticons/default/flag.gif) |
oldie914 |
Dec 23 2023, 01:15 AM
Member Group: Members Posts: 102 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
Back to the original question. I never rebuilt a 914/6 engine but did work on several 911's from the early 1970s. They all had the flat case bolt washers as shown in the first picture. I also made a porsche factory tour in 1971 and saw a 914/6 engine next to the 911's on the engine assembly line. Logically, porsche would use the same hardware on the 914/6 and 911 engines.
Krieger |
Dec 23 2023, 09:35 AM
My washers had the interior bevel.
Lo-Fi Version | Time is now: 28th May 2024 - 03:51 AM |
