Axles For 108mm Conversion, Possibility To Make Work |
914Sixer |
Jan 17 2024, 07:57 AM
914 Guru Group: Members Posts: 8,879 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I saw this and I thought they might work for 108mm axle conversion. They are 6 bolt but I have no idea about the bolt pattern. Good for 400 hp for the GTO, probably more than enough for 914 conversion. Something you might want to play with. Same length as stock 914 axle 20.25".
Attached thumbnail(s) |
burton73 |
Jan 17 2024, 09:27 AM
burton73 Group: Members Posts: 3,517 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
ogdougy |
Jan 17 2024, 10:07 AM
Newbie Group: Members Posts: 49 Joined: 9-May 22 From: Arizona Member No.: 26,536 Region Association: Southwest Region |
technicalninja |
Jan 17 2024, 11:41 AM
Senior Member Group: Members Posts: 1,208 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Ordered two of the cheap ones!
I've recently done a complete AC overhaul on a 06 GTO and the rear suspension and axles were MEATY! Driving it felt like a Camaro and a Corvette had a love child. It was a Holden and a bunch of it was way different than standard GM. Even the hood release is foreign feeling... It had the MOST powerful AC I've ever seen in a GM. Its problem was freeze up! I saw 18 degrees on a 100+ day. Could not buy a decent new compressor, had to have its compressor rebuilt... With much work got it UP to 33.5 degrees! Freaking fast, cold car... |
mb911 |
Jan 17 2024, 03:04 PM
914 Guru Group: Members Posts: 6,848 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I just got 911 complete half shafts and then floating empi axles from PMB it really was not very expensive. Unfortunately I have extra 911 axles now lol
bdstone914 |
Jan 18 2024, 06:36 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Rockauto shows one left as a cliseout. Amazon dhows them for $64. Anyone have experience with GSP brand? I know some CVs are junk and fail in a short time.
930cabman |
Jan 18 2024, 07:51 AM
Advanced Member Group: Members Posts: 3,052 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I wouldn't try a cheapie, who wants to get stranded when it fails?
technicalninja |
Jan 18 2024, 09:59 AM
When I can I re-boot OEM axles.
When the CVs are trashed I offer the customer OEM axles which are commonly over $500 each OR cheap Chinese copies. The replacement axles usually have different boots (that you cannot find down the road) and are of lower quality. Most have a "lifetime" warranty... When I'm installing Chinese axles, I ALWAYS replace the output seals on the tranny/rear end as leaks are stupid common. The Chinese axles have slightly different ODs and I can almost guarantee you will have leaks. What I haven't seen is axle failures. At least not in the last decade. The Chinese axles are always under 150 to the customer and I've had NO ONE choose the OEM stuff. Most of the time I can purchase the entire axle with a warranty for LESS than the cost of the OEM boot kits and its less work... I'm not a fan of Chinese parts but the axles appear to work fine. The axles that I bought via this thread were the least expensive I've EVER bought in 40 years... I bought them as "cores" to do experimentation with. Too cheap to resist! Thanks for the heads up @914sixer and @ogdougy |
technicalninja |
Jan 18 2024, 11:40 AM
True to Rock Auto...
When I don't need the parts tomorrow I get them overnight! When I desperately need the parts because I have a car stuck on my lift... The shipment goes to Puerto Rico first and sits there for 4 days before it makes its way to Texas (and it was coming from Tennessee!). That really happened! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Of course, the axles showed up today! Cost $9 and was less than 24 hours to delivery! Cheapest and NASTIEST axles I've ever bought. Looked like someone may have tried to install these and shipped them back. Moly CV grease EVERYWHERE! Still look meaty as hell! 10-1.5 mm mounting bolts. No obvious locating steps. Looks like they use JUST the bolts for alignment purposes and torque delivery. I prefer stull that locks together or, at least, has alignment pins/dowels to reduce twisting forces on the mounting hardware. I may call the 06 GTO I worked on back in to inspect the GTO flanges. Maybe these fit into a circular depression in the flanges. These were priced accordingly! |
914Sixer |
Jan 18 2024, 12:31 PM
Yeah, nothing better than having something to experiment at a bargain basement price. I would have done it but I do not have any 108mm stuff.
Maltese Falcon |
Jan 20 2024, 01:54 PM
Advanced Member Group: Members Posts: 4,641 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Hi Bob, wish my yardstick could indicate that 2/7"inch fraction ¿¿ Mathematics from way back Ming Dynasty ? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/marty914.jpg) |
mate914 |
Jan 20 2024, 08:30 PM
Matt Group: Members Posts: 748 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Hi Bob, wish my yardstick could indicate that 2/7"inch fraction ¿¿ Mathematics from way back Ming Dynasty ? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/marty914.jpg) Ming dynasty now that’s funny. You are a funny man. Matt |
Jack Standz |
Jan 23 2024, 11:31 PM
Member Group: Members Posts: 274 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
2006 PONTIAC GTO 6.0L V8
GSP NCV10024 CV Axle Wholesaler Closeout -- 30 Day Warranty $ 34.79 $ 0.00 1 $ 34.79 HERI 70462 CV Axle Wholesaler Closeout -- 30 Day Warranty $ 19.05 $ 0.00 1 $ 19.05 Well, the CVs look to be 930 "knock offs". The axles bolt up to 108mm stubs and transmission side flange (get a couple roll pins for each side). Both look to be the same length from my quick and dirty measurements with a tape measure. The axel length looks to be around 20 4/14 inches (IMG:style_emoticons/default/smile.gif) . You'll see that it's compared with a GNK/Lobro 911 axel that will use Patrick Motorsports adapters on the transmission side with a 5mm spacer on the hub side of the axel. So, yeah they'll work and with care and maybe slightly less HP, who knows how long they'll last? But, what do you care for a $19 or a $34 axel. I mean really, getting two 930 style CVS for $19 and a correct length axel and the boots. We will still be putting the GNK/Lobro axel on when the 911 e-brake and modified swing arms go on, but these will at least be spares. Thank you @914sixer for finding these and sharing! And others for finding the low cost ones! Can not believe $19 for an axel and only $16 for shipping both! Attached thumbnail(s) |
914Sixer |
Jan 24 2024, 07:01 AM
Glad to find out my hunch was right. Can't beat a deal like that.
Lo-Fi Version | Time is now: 13th May 2024 - 12:45 AM |
