Oil Cooler test location, Air speed results |
Trekkor |
Aug 20 2005, 09:14 PM
Mark came over and we did some testing with his hand held air speed guage.
Many readings were recorded. Readings are based on a short pass up to 70mph. Eventually all the front trunk rubber plugs were removed, large exit holes were drilled and a mock shroud was made. Air speed right at front trunk hole was 56mph. All holes open with the meter centered on the trunk floor- 17 mph mock shround in place with meter over exit hole and gravel guard off- 20mph With a proper shroud this should work quite well. KT Attached image(s) |
Lo-Fi Version | Time is now: 31st May 2024 - 08:38 PM |
