022 906 059 Dual Relay Work-Around?, Avoiding buying the obsolete and obscenely expensive 0 332 514 120 |
Artfrombama |
Feb 13 2024, 10:34 AM
Newbie Group: Members Posts: 49 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States |
I bought a non-running 1974 1.8, while I get spark the fuel pump refuses to run through the dual relay. Tested every way I know how and I can get the power side to actuate (click), the fuel pump side is dead.
My question, has any one done a work-around using the standard Bosch 5 pin relays? Attached thumbnail(s) |
Dlee6205 |
Feb 13 2024, 11:37 AM
Newbie Group: Members Posts: 46 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
There’s a lot of information over on ThaSamba on the subject. I believe the relay is the same for all LJet cars. Here’s one good example.
https://www.thesamba.com/vw/forum/viewtopic.php?t=362547 |
wonkipop |
Feb 13 2024, 03:13 PM
Advanced Member Group: Members Posts: 4,347 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
R Atwell has diagrams for a potential work around.
i have not had to do anything yet. fingers crossed - but i guess i will be doing this if i have to one day. unless some pop up for sale. https://www.ratwell.com/technical/DoubleRelay.html |
wonkipop |
Feb 13 2024, 03:15 PM
There’s a lot of information over on ThaSamba on the subject. I believe the relay is the same for all LJet cars. Here’s one good example. https://www.thesamba.com/vw/forum/viewtopic.php?t=362547 looks like a few folks have taken up ratwell's diagrams. (IMG:style_emoticons/default/beerchug.gif) |
ClayPerrine |
Feb 13 2024, 03:27 PM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There’s a lot of information over on ThaSamba on the subject. I believe the relay is the same for all LJet cars. Here’s one good example. https://www.thesamba.com/vw/forum/viewtopic.php?t=362547 The relay is the same for all 1.8L 914s. It is not the same relay used on all L-Jet cars. The VW implementations, and the 912E use different relays from the 914 version, and they are NOT interchangeable. |
jim_hoyland |
Feb 13 2024, 04:10 PM
Get that VIN ? Group: Members Posts: 9,312 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
See diagram of relay board. Ground spade III
The pump should run Attached image(s) |
ChrisFoley |
Feb 13 2024, 04:42 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Jim, the L-Jet dual relay being discussed is on the other side of the engine compartment.
jim_hoyland |
Feb 13 2024, 04:57 PM
ChrisFoley |
Feb 13 2024, 05:07 PM
Jim, the L-Jet dual relay being discussed is on the other side of the engine compartment. I realize that. This is a bypass. FP runs continuously when key is on. Gotcha, I've used that technique for carbed cars but never on injected. |
930cabman |
Feb 13 2024, 05:27 PM
Advanced Member Group: Members Posts: 3,109 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I bought a non-running 1974 1.8, while I get spark the fuel pump refuses to run through the dual relay. Tested every way I know how and I can get the power side to actuate (click), the fuel pump side is dead. My question, has any one done a work-around using the standard Bosch 5 pin relays? (IMG:style_emoticons/default/welcome.png) Will the fuel pump run if you connect it direct to 12V? It could be possible the relay is fine, but the pump is dead |
wonkipop |
Feb 13 2024, 06:43 PM
There’s a lot of information over on ThaSamba on the subject. I believe the relay is the same for all LJet cars. Here’s one good example. https://www.thesamba.com/vw/forum/viewtopic.php?t=362547 The relay is the same for all 1.8L 914s. It is not the same relay used on all L-Jet cars. The VW implementations, and the 912E use different relays from the 914 version, and they are NOT interchangeable. that may be so. but....... i have the black plastic superceding relay. bosch 0 333 514 120 that r atwell uses/discusses on his website. 74 1.8. been on car since 89. got the metal one replaced in chicago. i did not do it myself back then (L Jet EFI was something i looked at and my eyes glazed over (IMG:style_emoticons/default/biggrin.gif) ). there was a little mod they do with the wiring. @Van B was on to it with his car and there was a discussion about it a couple of years ago on a thread Van was running. so its for sure that what r atwell has diagrams for on his website must work in some way for the 914 too as its exactly the same relay being used. i think 0 333 514 120 is the much later superceding part that replaced the original earlier metal ones and i think the black plastic one is universal for the L jet in all the VW applications of that era. ie the L jet beetle. L jet 412 and some of the buses. as to bypassing the fuel pump shut off. all good and well. but it is an inbuilt safety design that came with the L jets. fuel pump cuts off if engine stops running even if ignition is on. seems to me if you can figure out the way to make two relays into the dual relay set up as per ratwell diagrams its a good way to go rather than make a degraded system so to speak. its probably what i will do if the one on mine gives up the ghost. will try and make one. |
wonkipop |
Feb 13 2024, 06:56 PM
this is the one that is in my 74 since 1989.
even back then it was not a straight plug in replacement for the orig metal one. there was a little wiring mod they did. VW mechanics had the work around for this relay replacement and knew how to do it without thinking. a lot of L jets these days would have this plastic replacement though just as many still probably have the factory original. i'd never stopped to figure out there was a wiring mod for it to go in but Van B figured it out as to exactly what got slightly changed to do it. but of course these days the once available plastic relay has become unobtanium. bosch stopped making it in 2013. last time a batch was run. |
jim_hoyland |
Feb 13 2024, 07:27 PM
Jim, the L-Jet dual relay being discussed is on the other side of the engine compartment. I realize that. This is a bypass. FP runs continuously when key is on. ** I installed an under dash switch to activate this bypass- Just in case! |
Artfrombama |
Feb 14 2024, 12:11 AM
I bought a non-running 1974 1.8, while I get spark the fuel pump refuses to run through the dual relay. Tested every way I know how and I can get the power side to actuate (click), the fuel pump side is dead. My question, has any one done a work-around using the standard Bosch 5 pin relays? (IMG:style_emoticons/default/welcome.png) Will the fuel pump run if you connect it direct to 12V? It could be possible the relay is fine, but the pump is dead The fuel pump will run if I manually close the relay (cover off) or if I jump the terminals on the relay board. Yes the fuel pump runs. |
ClayPerrine |
Feb 14 2024, 06:43 AM
I bought a non-running 1974 1.8, while I get spark the fuel pump refuses to run through the dual relay. Tested every way I know how and I can get the power side to actuate (click), the fuel pump side is dead. My question, has any one done a work-around using the standard Bosch 5 pin relays? (IMG:style_emoticons/default/welcome.png) Will the fuel pump run if you connect it direct to 12V? It could be possible the relay is fine, but the pump is dead The fuel pump will run if I manually close the relay (cover off) or if I jump the terminals on the relay board. Yes the fuel pump runs. Does the pump run if you open the air flow meter flap? |
Artfrombama |
Feb 14 2024, 10:04 AM
QUOTE Does the pump run if you open the air flow meter flap? No. I have continuity when I move the flap but no action from the relay. |
dr914@autoatlanta.com |
Feb 14 2024, 11:54 AM
914 Guru Group: Members Posts: 7,875 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
easier to just repair yours and keep the factory wiring and function. Our man sean Buckley repairs them all of the time for our customers
I bought a non-running 1974 1.8, while I get spark the fuel pump refuses to run through the dual relay. Tested every way I know how and I can get the power side to actuate (click), the fuel pump side is dead. My question, has any one done a work-around using the standard Bosch 5 pin relays? |
ejm |
Feb 14 2024, 12:27 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
ClayPerrine |
Feb 14 2024, 01:09 PM
QUOTE Does the pump run if you open the air flow meter flap? No. I have continuity when I move the flap but no action from the relay. That is either a bad relay, or the wrong relay. The circuit from the Air flow meter to the relay has the pin in a different spot on some of the relays. If you have the incorrect relay, you can always move the pin in the plug. |
Artfrombama |
Feb 14 2024, 05:06 PM
QUOTE Does the pump run if you open the air flow meter flap? No. I have continuity when I move the flap but no action from the relay. That is either a bad relay, or the wrong relay. The circuit from the Air flow meter to the relay has the pin in a different spot on some of the relays. If you have the incorrect relay, you can always move the pin in the plug. I have what I believe is the original relay. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 28th May 2024 - 05:59 PM |
