Quick Run Through on Gun Barrel Black Oxide Finish, Caswell Kit |
914Sixer |
Mar 4 2024, 06:42 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Clean your parts to the max. Soaked in vinegar and the wire brushes to get to the pitted rust. Clean up in soap and water. I wiped down with lacquer thinner, through drying required. Did two dippings, cleaning oxide off with 00 steel wool both times. Rinsed in distilled water (NO Minerals). Hit with steel wool again. Next up, coated parts with penetration oil. Not required BUT I heat up the parts after oil bath. Let oil cook off. Dip again the let stand over night. Good hard coating. Caswell offers protective coating but I like LPS3. Just a quick run though.
Dion |
Mar 4 2024, 07:46 PM
RN Group: Members Posts: 2,762 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
That’s awesome. Nice, would love to give that a go.
jmargush |
Mar 4 2024, 09:14 PM
Member Group: Members Posts: 458 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
How do you go about heating them? And how hot do you have to get them?
914Sixer |
Mar 5 2024, 06:43 AM
Heat gun on high. Got parts hot to the touch
StarBear |
Mar 5 2024, 08:17 AM
Senior Member Group: Members Posts: 1,851 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Awesome! Great job. (IMG:style_emoticons/default/biggrin.gif)
friethmiller |
Mar 5 2024, 11:56 AM
Member Group: Members Posts: 463 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) I used a Caswell kit to plate parts on my last 914. Learned a lot! #1 rule - completely clean your parts!! #2 rule - spend time creating a rack to hang your plated parts until they dry. Everything else is pretty easy.
burton73 |
Mar 5 2024, 01:47 PM
burton73 Group: Members Posts: 3,508 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
https://www.youtube.com/watch?v=PGpYh-_llzE
Gun Bluing Steel Parts Tutorial I was thinking that I had some custom work done on a 45ACP in 1983. The combination of high polish and areas of glass beaded for a satin finish came out looking great. I do not know if this kind of finish would work instead of the Caswell kit but take a look. Best Bob B |
mb911 |
Mar 5 2024, 03:26 PM
914 Guru Group: Members Posts: 6,815 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have now started sort of offering a service for plating ironically. A few folks have sent me their prepped hardware and I drop it off at a local plater. They typically charge me about 150-200 for an entire cars worth of parts. It’s way easier than the caswell kit. I tried that kit and just very sensitive so I leave it to the experts.
Those look really good btw |
windforfun |
Mar 5 2024, 05:05 PM
Senior Member Group: Members Posts: 1,776 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Those parts look beautiful indeed.
So is the black oxide finish the same process that gun manufacturers use to "blue" their metal? |
914Sixer |
Mar 5 2024, 06:34 PM
Thinking gun barrel finish refers to how smooth it turns out, not actual blueing process.
aharder |
Mar 5 2024, 08:07 PM
Advanced Member Group: Members Posts: 4,374 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Great job Mark !!
gereed75 |
Mar 6 2024, 07:48 AM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
That black coating looks great. There are a great many variations on what are termed “black oxide”. See attached
https://finishingandcoating.com/index.php/c...-oxide-coatings Not sure where this particular treatment falls. Other than a decorative effect, it comes down to how rust resistant it is. The standard is testing in a salt spray cabinet That is a whole nother subject of study. The manufacturer of the process usually tests and publishes the results for comparison to other treatments. |
Lo-Fi Version | Time is now: 28th April 2024 - 10:39 PM |
