914-6 throttle rod ….new |
sixaddict |
Mar 7 2024, 08:03 AM
Senior Member Group: Members Posts: 801 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
NARP74 |
Mar 7 2024, 09:03 AM
Senior Member Group: Members Posts: 1,063 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Ahhh, the hundred dollar coat hanger...
930cabman |
Mar 8 2024, 01:35 PM
Advanced Member Group: Members Posts: 3,062 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Slight hijack, but has anyone used the /6 conversion throttle cable from PMS? about $150, but looks like the EZ button
mb911 |
Mar 8 2024, 02:38 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
TMM914 |
Mar 8 2024, 04:03 PM
Newbie Group: Members Posts: 33 Joined: 1-January 20 From: St Jacobs Ontario Canada Member No.: 23,786 Region Association: Canada |
I hit the same easy button.
JmuRiz |
Mar 8 2024, 04:04 PM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Does the PMS unit replace the need for the rod and bellcrank? Not sure if I understand how it's routed and hooks up.
ASking as my 914/4 had carbs and just had a throttle cable that routed into the engine bay and mounted a tab to the engine case to the cross-bar linkage. |
nditiz1 |
Mar 8 2024, 04:56 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I did it on mine as well.
It hooks to the trans with one bracket then extends through the engine metal to connect to your dual carb linkage off the manifolds. I guess you could also hook into the stock throttle plate if using a CIS engine. Short answer: yes does replace the rod and bell crank. |
sixaddict |
Mar 9 2024, 08:56 AM
So glad someone asked the “dumb” question and I also understand how the PMS part works.
Wanted this for my real six restoration…..but have a couple original ones to sell. Are they worth $65 plus shipping? Attached thumbnail(s) |
NARP74 |
Mar 9 2024, 10:20 AM
Any links to the PMS part? I have trouble finding things on that site sometimes. My car came with a 6, all the 911 stuff missing for the throttle. Kind of a kludge in place but it works. Like to get something more repeatable and reliable.
nditiz1 |
Mar 9 2024, 11:30 AM
@OP - $65 seems fine. I'd even take $65 shipped for the one I have laying around.
Here is the link for the PMS one, replace that worn out throttle cable too. https://patrickmotorsports.com/products/eng...31da9&_ss=r |
NARP74 |
Mar 9 2024, 05:39 PM
Way off topic for a FS ad, but does anyone have pics of the PMS part installed? I am missing most of the stock 911 accel cable parts so I am not sure what I would need to use it.
mate914 |
Mar 10 2024, 08:20 AM
Matt Group: Members Posts: 749 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Kind of on topic. With the original coat hanger setup, if the throttle sticks your carbs still close. With the cable going to carb cross bar and the throttle sticks, carbs stay open. That is a safety feature I think is important.
I could use another coat hanger for a spare. I just cant tell 914-6 from 911 difference, length maybe. Matt |
nditiz1 |
Mar 10 2024, 01:49 PM
I'm not sure I follow. How does the original setup prevent the carbs from sticking? If the carbs are stuck open with either application the pedal will just stay on the floor. The only spring tension is that on the throttles and the shafts.
mate914 |
Mar 10 2024, 07:29 PM
I'm not sure I follow. How does the original setup prevent the carbs from sticking? If the carbs are stuck open with either application the pedal will just stay on the floor. The only spring tension is that on the throttles and the shafts. Your right I'm wrong. I was thinking hoop in $100 coat hander would fix this. Then I tried it. Matt |
mate914 |
Mar 10 2024, 07:30 PM
Lo-Fi Version | Time is now: 16th May 2024 - 03:42 AM |
