Fun with troubleshooting leanness (and 5th gear cruising temps) |
emerygt350 |
Apr 3 2024, 09:36 AM
Advanced Member Group: Members Posts: 2,081 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
That is pretty much exactly what I am seeing.
brant |
Apr 3 2024, 10:02 AM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree with wind resistance
Also when you drop into an over drive 5th you drop the fan speed This is why the factory put a different 5th I believe into the /6 car trans To not have as much of an over drive ratio in 5th to raise the fan speed and head cooling output The 356 guys used to drive a gear down to increase cooling to the heads You could change your gear ratio? It’s not a heavy load at cruising Steady state cruising is supposed to be leaner than WOT for gas mileage |
brant |
Apr 3 2024, 10:09 AM
12-1 at cruising is too much fuel
Washed the oil film more Increases wear on the motor WOT should be 12.5:1 to flood the cylinder under that condition as the charge actually cools the head more for load when it’s needed But not at steady state cruising And why a pot that changes across the whole range can be detrimental compared to the factory tune that can adjust for conditions and throttle conditions |
emerygt350 |
Apr 3 2024, 12:48 PM
12-1 at cruising is too much fuel Washed the oil film more Increases wear on the motor WOT should be 12.5:1 to flood the cylinder under that condition as the charge actually cools the head more for load when it’s needed But not at steady state cruising And why a pot that changes across the whole range can be detrimental compared to the factory tune that can adjust for conditions and throttle conditions Yeah, 12 is definitely not good at cruise, I was shooting for 13.5. With nothing but MPS mods, it sits at 13.8-9 now at 3200 rpm 72 mph, 12-13inhg. I haven't been able to test my fat switch due to the craptastic weather we are having but from my previous experiments I suspect it will bring me to 13ish. What I am hoping for now is a 'oh jeeze, thats a long climb' switch for the interstate. Out here in upstate ny you can end up climbing 1500 feet over 75 miles with no break as you head west from Elmira. I don't want to be in a position where I am hitting 400 and can't do anything but slow down. No idea if this will actually help that, but it is harmless to try. |
Apr 3 2024, 04:22 PM
Custom Member Group: Members Posts: 24,571 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Somewhere out there online is a doc, drawing and pictures of the aero dynamic testing done by a member many years ago….
I’m recalling a set of tests to measure air going into the engine lid, along with temps with and without the rain tray…lots of good tests. Tray or not makes no difference. Side vents, like the Boxster, would probably work great. I recall getting air into the engine lid was actually harder at higher speeds. Might be worth a hunt to go find old info on 914 aero dynamics |
Apr 3 2024, 04:23 PM
I’m going to add some custom louvers on the side like a 550 spider.
My goal is a fresh air intake and allow the fan to have all the air dedicated to cooling. |
emerygt350 |
Apr 3 2024, 04:39 PM
That would be interesting, I do have quite the air dam on my car so I am sure that doesn't help. I did put some remote sensing equipment in there a couple years ago, temps in the engine stayed pretty reasonable but things have changed.
Apr 3 2024, 06:49 PM
Bottoms of cars have smooth panels now.
The two air flaps on the bottom of the rear firewall are proven to lower temps. Air dam……no clue if that helps or hurts |
VaccaRabite |
Apr 3 2024, 08:24 PM
En Garde! Group: Admin Posts: 13,432 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Bottoms of cars have smooth panels now. The two air flaps on the bottom of the rear firewall are proven to lower temps. Air dam……no clue if that helps or hurts Air dam hurts. +10* is what people generally report. For mine I don't run the rubber lower section of the air dam. Zach |
Apr 3 2024, 08:34 PM
I cannot tell from your avatar picture….but it looks like a splitter with possibly a rubber dam below?
If it’s not super hard…take it off and test it |
emerygt350 |
Apr 4 2024, 05:06 AM
Only the splitter, no rubber dam (I was referring to the whole darn thing as the air dam). It is 'attached' so I can't experiment with that, but compared to stock it must be creating some extra resistance.
era vulgaris |
Apr 4 2024, 06:11 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
I’m recalling a set of tests to measure air going into the engine lid, along with temps with and without the rain tray…lots of good tests. Tray or not makes no difference. I found this to be the case also. August in North Carolina, generally in the mid 90's with 80-90% humidity. I removed the rain tray and ran two weeks without it just to see if there was any difference. Head and oil temps were exactly the same. Operating temp is operating temp, and has more to do with state of tune as well as whether all the cooling tins are in place. Over the course of an entire year, through winter and summer, I also saw ambient temps make no difference in head temps, however oil temps were slightly higher in the summer (although not enough to be concerned about) even with a remote oil cooler with thermostatically activated fans. |
brant |
Apr 4 2024, 08:48 AM
It’s not the resistance that is a problem from a low air dam
It’s the cooling Under air is required to help evacuate the hot air and increase the temperature fficiency of the stock cooling design 10 degrees was my result also from my own experience with air dams |
emerygt350 |
Apr 4 2024, 09:24 AM
Ahh, yes, I see. I suppose that big oil cooler slot lets some through.... nothing like a regular front of course.
Lo-Fi Version | Time is now: 2nd May 2024 - 11:09 PM |
