Dry sump leakdown prevention? |
gnomefabtech |
Mar 25 2024, 11:02 AM
Member Group: Members Posts: 96 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Hello!
So I'm running a dry-sump system on my 'teen and it's all great except if the car sits for a few days the oil in the tank slowly fills the motor. This wouldn't be a big deal except it floods the turbo and then there's smoke. So much smoke. Does anyone have experience using a low cracking pressure check valve to hold the oil in the tank until the car is running? I see a selection of these on McMaster but I'm understandably nervous about restricting the flow into the engine from the tank. It's a -12 an line coming out of the tank. What did Porsche do about this on their dry-sump systems? I'm running a Hayabusa engine (build thread to follow) so it's a pretty unconventional build but the oiling thing is common to all dry-sumps. Thanks for answering these questions. |
GregAmy |
Mar 25 2024, 11:18 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Edit:
I have dry sump in my /4 race car. I put a manual valve in the tank line, that I turn off after each session and clip my master switch key to it as a reminder. There are drainback valves for the 911s; Rothsport and Willhoit come to mind. |
gnomefabtech |
Mar 25 2024, 09:42 PM
Thanks for the suggestion. $300 is pretty steep for one of those valves. I'll see if I can find a more thrifty option first.
fixer34 |
Mar 25 2024, 09:54 PM
Senior Member Group: Members Posts: 1,076 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Rothsport. Is your engine worth more than $300?? Mine is on a factory -6, there are 911 versions also. This is NOT your run of the mill 'check valve'. Too little sealing pressure and you might as well not bother; too much and you get oil starvation on startup followed shortly by spun bearings.
Some things in life you can go cheap on; this isn't one of them. |
Mar 26 2024, 04:59 AM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You might be able to find a used one on pelican. Not everyone is a fan.
mlindner |
Mar 26 2024, 05:24 AM
Senior Member Group: Members Posts: 1,514 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
gnomefabtech |
Mar 26 2024, 07:02 PM
Thanks for the replies. My oil line is a -12 AN so I have to also adapt to use the Rothsport unit. DOes anyone know the diameter of the stock Porsche "S" hose the valve clamps into?
sixnotfour |
Mar 26 2024, 07:21 PM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I have a rear mounted oil tank and going install a 1/4 turn manual valve.. and I have a pressure gauge ...soo....
Thanks @gnomefabtech |
gnomefabtech |
Mar 26 2024, 07:54 PM
SIXNOTFOUR- I like your resourcefulness there but I think that valve might not be rated for the heat of the oil. Also, an Amazon "no Q.C." part might be a bit of a risk in a critical place like the oiling system.
THere are some low cracking pressure check valves that might work. I'll order one and report back. One like this: https://www.mcmaster.com/1874N19/ |
yeahmag |
Mar 27 2024, 10:11 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I use a quarter turn valve at the tank as well.
stownsen914 |
Mar 27 2024, 10:44 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Depending on where the tank is mounted and how the car is used, there is another option. If the tank is front mounted, you can store the car jacked in the rear (or rear tires rolled onto a couple boards to elevate). This puts the engine higher than the tank, and keeps more of the oil in the tank. For frequent use it might be inconvenient, but I've done the above for 911 and 914 racecars and it works like a charm.
I'm not keen on putting something in the oil feed line to my motor. Too easy to forget, or have it fail, and trash the motor almost instantly. |
ClayPerrine |
Mar 27 2024, 03:14 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I'm not keen on putting something in the oil feed line to my motor. Too easy to forget, or have it fail, and trash the motor almost instantly. (IMG:style_emoticons/default/agree.gif) I actually tried a Rothsport check valve on my 4.0L motor. It would not allow oil to pass through it. ZERO oil pressure. The guys at Rothsport worked with me and they could not figure out why it didn't work. So I gutted it, and eventually put in a new line without the check valve. Not trashing Rothsport. They supported it and I will never asked for a refund. But it just didn't work for me, and I can't risk my expensive motor for it. |
arbitrary |
Mar 27 2024, 03:40 PM
Member Group: Members Posts: 81 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
What pressure pump is the Hayabusa engine using? Is it worn to the point where oil is getting past the gears into the “sump”
gnomefabtech |
Mar 27 2024, 06:32 PM
What pressure pump is the Hayabusa engine using? Is it worn to the point where oil is getting past the gears into the “sump” The dry-sump system I am using is a hybrid that uses the stock high pressure pump and adds a two stage scavenge to empty the sump. Since the 'Busa oil pump was never designed to stop flow when stopped it doesn't. This wouldn't be a problem except that my turbo is mounted a bit low so it gets flooded with oil when there's a lot of drainback. Here's a pic of the engine before it went in. I'll start another thread with more details. There are a LOT of details. |
Mar 27 2024, 08:04 PM
Custom Member Group: Members Posts: 24,569 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Stock 84 3.2 911 here.
Why does mine work? Mine is all stock. |
arbitrary |
Mar 28 2024, 07:46 AM
I have a Hayabusa engine in a Caterham; it uses a dry sump system from SBD Motorsports. https://sbdmotorsport.co.uk/ They recommend that the bottom of the dry sump tank is at the same height as the bottom of the sump.
I used to have a 993tt - they would often have oil back flow issues. The solution had multiple facets: - the correct Porsche oil filter that had a non-return valve built in - a pressure valve at the oil feed line going into the turbo (pretty sure it was a 996tt part) that would only open under a slight pressure (greater than the head provided by the dry sump tank) - the highest viscosity oil allowed - scavenge lines (developed by Ruf?) that had a raised section acting as an anti-siphon But not sure any of those will help your situation… I’m guessing your turbo is a gravity drain back to the engine sump? Can you connect it via a T fitting to the scavenge side of the pump instead with a raised section like Ruf did? Please do keep posting - I like Hayabusa engines and I like 914s. (IMG:style_emoticons/default/biggrin.gif) |
gnomefabtech |
Mar 28 2024, 10:03 AM
I think it has to do with how good your valve seals are and how old your oil pump is.
technicalninja |
Mar 28 2024, 01:28 PM
Senior Member Group: Members Posts: 1,163 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
What pressure pump is the Hayabusa engine using? Is it worn to the point where oil is getting past the gears into the “sump” The dry-sump system I am using is a hybrid that uses the stock high pressure pump and adds a two stage scavenge to empty the sump. Since the 'Busa oil pump was never designed to stop flow when stopped it doesn't. This wouldn't be a problem except that my turbo is mounted a bit low so it gets flooded with oil when there's a lot of drainback. Here's a pic of the engine before it went in. I'll start another thread with more details. There are a LOT of details. I want to hear that run! (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Scratch pics and add audio soundtrack! |
gnomefabtech |
Mar 28 2024, 09:21 PM
gnomefabtech |
Apr 5 2024, 12:07 PM
I solved it. I am using this valve here:
https://www.mcmaster.com/1874N19/ I added a couple -12AN fittings (you could use barbed if you want that) and plumbed it in between the tank and the engine. Does a good job of preventing the oil from draining down and I see no change in the operating oil pressure. The only down side is that valve is kind of bulky. Not really a problem though. Total cost of $130 shipped. |
Lo-Fi Version | Time is now: 29th April 2024 - 03:51 AM |
