WTB 914 6 / 911 oil hose nipple, oil plumbing nipple |
rgalla9146 |
Mar 28 2024, 06:04 AM
I want to buy the straight 20/22 mm threaded part in the picture.
I don't need the hose or the collar. The part can be steel or aluminum, either will work but prefer aluminum TIA Rory Attached thumbnail(s) |
aturboman |
Mar 28 2024, 08:31 AM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
Hi Rory I'll look on the weekend if I have any used originals and will gladly send you what I have.
I purchased new Aluminum fittings via this S Registry member, and they are perfect. https://www.early911sregistry.org/forums/sh...-901-107-813-04 My suggestion is contacting Jimmy, he's a great seller I've dealt with several times. Robert |
911_2.2T |
Mar 28 2024, 11:26 AM
Newbie Group: Members Posts: 8 Joined: 4-September 12 From: Netherlands Member No.: 14,890 Region Association: Europe |
I want to buy the straight 20/22 mm threaded part in the picture. I don't need the hose or the collar. The part can be steel or aluminum, either will work but prefer aluminum TIA Rory Jimmy has these, I've contacted him a couple months ago to do a run of these and they came out great. He also has the argus straight type fittings and many more parts for 914GT https://www.early911sregistry.org/forums/sh...-901-107-813-04 |
rgalla9146 |
Mar 28 2024, 12:01 PM
I want to buy the straight 20/22 mm threaded part in the picture. I don't need the hose or the collar. The part can be steel or aluminum, either will work but prefer aluminum TIA Rory Jimmy has these, I've contacted him a couple months ago to do a run of these and they came out great. He also has the argus straight type fittings and many more parts for 914GT https://www.early911sregistry.org/forums/sh...-901-107-813-04 Jimmy has replied to this WTB Thanks for the tip |
Lo-Fi Version | Time is now: 29th April 2024 - 01:41 AM |
