Minnesota or Wisconsin Shop for Metal Work |
DaveB |
Mar 30 2024, 09:37 AM
Member Group: Members Posts: 163 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest |
Have you thought about just doing enough to make it road safe? Enjoy driving the kids around and get a ton of pictures. Later when they are teens, take some hobbyist welding classes with them and make it a family project to replace the hell hole, floor pans, etc. Pull together a cut list and spend the next several years finding parts with the kids. When they tell the person selling a part that is cost too much, you have success!
DaveB |
collinvon |
Mar 30 2024, 01:30 PM
Newbie Group: Members Posts: 42 Joined: 11-June 19 From: St. Paul, Minnesota Member No.: 23,207 Region Association: Upper MidWest |
collinvon |
Mar 30 2024, 01:32 PM
Have you thought about just doing enough to make it road safe? Enjoy driving the kids around and get a ton of pictures. Later when they are teens, take some hobbyist welding classes with them and make it a family project to replace the hell hole, floor pans, etc. Pull together a cut list and spend the next several years finding parts with the kids. When they tell the person selling a part that is cost too much, you have success! DaveB It actually ran and drove before I parked it, but the reason it was parked is that it wasn't really adding more band aids in my opinion. Unfortunately, it seems like most of the metal work needs to be done for it to be reasonably safe to drive, but the good news is I'm not in a hurry at all. If it isn't worth putting money into, I think that would be my plan is just to let it sit until I can work on it with the kids. Thanks for the input! |
collinvon |
Mar 30 2024, 01:33 PM
rick 918-S |
Mar 30 2024, 01:53 PM
Hey nice rack! -Celette Group: Members Posts: 20,434 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Well it was done once. The key to value is doing it correctly.
technicalninja |
Mar 30 2024, 02:11 PM
Senior Member Group: Members Posts: 1,173 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
This recent thread shows what a bad one is like.
It's most impressive regarding the guy who is doing the work. Limited tools and no shop at all! Works coming out nice IMO. http://www.914world.com/bbs2/index.php?showtopic=368359 Compare your car to that. I agree with Ben. Pretty decent on driver's side. It's the passenger's side that gets gang banged by acid then water due to the placement of the battery. Almost guaranteed destruction if it's ever been rained on. Rain overfills non-sealed battery, when charged overfilled battery pukes acid all over hell hole. Lather, rinse, repeat, RUST... Look at what Fred had to do at that point. He's a BADASS in my book! No way I'd go that far on a non-special car. His is an LE however and that (almost!) makes it worth saving in my book. He will be completely successful IMO. And, if I run a battery in the stock location it will be, at a minimum, a sealed AGM unit that cannot leak anything... |
Mar 30 2024, 03:30 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mar 30 2024, 03:38 PM
This recent thread shows what a bad one is like. It's most impressive regarding the guy who is doing the work. Limited tools and no shop at all! Works coming out nice IMO. http://www.914world.com/bbs2/index.php?showtopic=368359 Compare your car to that. I agree with Ben. Pretty decent on driver's side. It's the passenger's side that gets gang banged by acid then water due to the placement of the battery. Almost guaranteed destruction if it's ever been rained on. Rain overfills non-sealed battery, when charged overfilled battery pukes acid all over hell hole. Lather, rinse, repeat, RUST... Look at what Fred had to do at that point. He's a BADASS in my book! No way I'd go that far on a non-special car. His is an LE however and that (almost!) makes it worth saving in my book. He will be completely successful IMO. And, if I run a battery in the stock location it will be, at a minimum, a sealed AGM unit that cannot leak anything... “gang banged“ - Too funny! The chassis holds a lot of water and battery acid mixture in the inner sections. It sits there for long periods and causes the car to rust from the inside out. There are also a number of inner body panels that are foam filled. They are rust incubators as well. It takes a while to see the real rust issue and sometimes you won’t know the extent until you really dig deep. |
worn |
Mar 30 2024, 07:54 PM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
That doesn’t look terrible. Fingers crossed the passenger side is similar. The, is that a jack point?, is obviously flaky, but I have no idea where the line is drawn between salvageable and needs to be replaced. I am going to guess that you are already hooked. Me, twice. Bought unaware of the problems. Don’t want to be the guy that hand’s problems to someone else. Don’t want to see it crushed. So, that leaves you, if you are me, with a MIG welder torch in your hand trying to learn how not to burn holes in the panel. It can be done. It might help your children learn how to push metal around. It isn’t likely to be fast. I would be willing to swing by a couple of times, on I94. |
rick 918-S |
Mar 30 2024, 09:42 PM
That doesn’t look terrible. Fingers crossed the passenger side is similar. The, is that a jack point?, is obviously flaky, but I have no idea where the line is drawn between salvageable and needs to be replaced. I am going to guess that you are already hooked. Me, twice. Bought unaware of the problems. Don’t want to be the guy that hand’s problems to someone else. Don’t want to see it crushed. So, that leaves you, if you are me, with a MIG welder torch in your hand trying to learn how not to burn holes in the panel. It can be done. It might help your children learn how to push metal around. It isn’t likely to be fast. I would be willing to swing by a couple of times, on I94. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:09 AM |
