early window re-install, how to attach the window regulator button |
dgw |
Mar 28 2024, 07:29 PM
Dennis Winter Group: Members Posts: 552 Joined: 7-January 03 From: Santa Cruz Mountains Member No.: 106 Region Association: Northern California |
how do you get the little white window regulator button on the lift pin on the rotating cable? it looks like the side of the button in the third picture (narrow slot) goes over the two prongs shown in the second picture but i can't imagine how to make that happen.
second picture third picture |
IronHillRestorations |
Mar 29 2024, 05:33 AM
Carefully bend them
dgw |
Mar 29 2024, 10:54 AM
Carefully bend them I thought about that, but then you can't bend them back after the button is on there. The tabs are there to hold the button in place. Thinking about it this morning, maybe everything fits tight enough that it doesn't matter. Bending the tabs looks like the only option. |
Mikey914 |
Mar 29 2024, 11:38 AM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I was looking for my pics, but I was pretty sure the original tabs weren't bent out. At least on my car. I'll check later today.
914sgofast2 |
Mar 29 2024, 11:40 AM
Senior Member Group: Members Posts: 613 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
My car is a December 1969 build and the tabs were bent out slightly to keep the plastic button on.
Mar 29 2024, 12:14 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
They look overly bent. Take a look at your other window winder.
dgw |
Mar 30 2024, 06:33 PM
Carefully bend them I thought about that, but then you can't bend them back after the button is on there. The tabs are there to hold the button in place. Thinking about it this morning, maybe everything fits tight enough that it doesn't matter. Bending the tabs looks like the only option. Straightening the original tabs turned out to be the solution for me. The didn't both have to be totally straight, I left one bent more than the other but a bit of force popped it on. |
Lo-Fi Version | Time is now: 29th April 2024 - 06:43 AM |
