‘75 Ignition lock disassembly, ******Got it out********* |
jim_hoyland |
Mar 29 2024, 12:12 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I want to remove the part the key goes into. How can I get it out ???
Attached thumbnail(s) |
jim_hoyland |
Bottom shot
76-914 |
Mar 29 2024, 02:25 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Put the key in it and pull it out. Are uyou replacing that black plastic trim ring? If it is one Curt had made you don't need to pull anything. It slips on in place. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland |
Mar 29 2024, 04:00 PM
Put the key in it and pull it out. Are uyou replacing that black plastic trim ring? If it is one Curt had made you don't need to pull anything. It slips on in place. (IMG:style_emoticons/default/beerchug.gif) Thanks. No trim piece I did try putting the key in, turning it and pulling. Nada, should the key be twisted ? I’ll try pulling harder next time’ |
jim_hoyland |
Mar 29 2024, 04:02 PM
And, is there a hidden screw holding it ?
ejm |
Mar 29 2024, 04:19 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
There is a spring tab holding it in. You need to drill a hole in the correct spot to push the tab in to release the lock. Use the new lock to locate where the hole needs to be.
sixnotfour |
Mar 29 2024, 05:46 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Hi Jim...Great how to, with Pictures...
http://www.914world.com/bbs2/index.php?sho...p;#entry2283393 |
sixnotfour |
Mar 29 2024, 05:49 PM
jim_hoyland |
Mar 29 2024, 06:42 PM
Thanks; great pics. I’ll revisit the assembly tomorrow |
barefoot |
Mar 30 2024, 05:26 AM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
jim_hoyland |
Mar 30 2024, 07:39 AM
F
The pictures really helped: Turned out there was a hole already drilled, all I had to do was push down on the spring and the lock pulled out. Attached thumbnail(s) |
TROJANMAN |
Apr 1 2024, 07:24 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Nice job Jim.
Are you driving to Mesquite this year? |
jim_hoyland |
Apr 1 2024, 03:46 PM
Porschef |
Apr 1 2024, 04:46 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Jim, what was your reason for pulling out the switch?
jim_hoyland |
Apr 1 2024, 05:49 PM
Jim, what was your reason for pulling out the switch? I wanted to save the switch after completely removing the entire switch assembly. I previously installed a switch on the left side and didn’t need the original assembly. After the column assembly was removed a new clam shell was installed. These pics might help Attached thumbnail(s) |
jim_hoyland |
Apr 1 2024, 05:50 PM
Left side:
The original switch will be a back up in the event the left side switch fails. All I would need to do is unplug the dead switch and plug into the new spare Attached thumbnail(s) |
Porschef |
Apr 1 2024, 06:08 PM
Ok, I want to get my wheel lock working again. If’n I can’t figger it, I’ll likely send it off to Mr. Curtiss.
Thanks (IMG:style_emoticons/default/beerchug.gif) |
jim_hoyland |
Apr 1 2024, 07:58 PM
Ok, I want to get my wheel lock working again. If’n I can’t figger it, I’ll likely send it off to Mr. Curtiss. Thanks (IMG:style_emoticons/default/beerchug.gif) IIRC there’s a thread on that…,.., |
sixnotfour |
Apr 2 2024, 04:59 PM
2 of a Kind.. (IMG:style_emoticons/default/beerchug.gif) PMB has the 3d printed version..75-76 presently
Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:39 PM |
