How do I wire a '71-73 911 turn signal switch into '71 914 harness |
morehills |
Apr 4 2024, 06:11 AM
Newbie Group: Members Posts: 23 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States |
Now that the structural changes are done on my GT interior, I'm moving on to wire in the turn signal, ignition and wiper switches. It makes my brain ache to study the wiring diagrams from my '71 914 (early 12 pin harness), and the 1971 911 and 914-6 diagrams. Differences between them all and I'm a less than proficient electrician.
Here's a chart I made for the turn signal and ignition connections (thanks to Jeff Bowlsby, Clay Perrine and Tom Butler for groundwork posts and advice): https://docs.google.com/spreadsheets/d/1Hvk...dit?usp=sharing My biggest remaining questions go to a couple wires from the 911 turn signal harness that run outside the 914 12 pin connector. I've labeled them in the chart above as position 15 and 16 (on the right). 15 is a red/white wire which runs from the switch bundled with the parking light wires, and from the 911 diagram it appears to be always on power connecting to the light switch. And 16 is a black wire coming back from the 6 prong plug. Can anyone confirm how they are used? I'd be very appreciative of anyone who has put a 911 column in an early car helping me out. Am I on the right track or just smoking it? Thank you, John |
windforfun |
Apr 4 2024, 02:22 PM
Senior Member Group: Members Posts: 1,790 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Are all the 914 connections made in a logical fashion? Your Excel file is a wee bit difficult to easily grasp. If so, then ignore the left over wires from the 911 switch. Maybe this is a super stupid suggestion.
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Apr 4 2024, 02:55 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I think tge 924/944 turn signal switch is a minor change over
saladin |
Apr 15 2024, 11:03 AM
Newbie Group: Members Posts: 38 Joined: 18-September 07 From: Mountain View, CA Member No.: 8,125 Region Association: Northern California |
@morehills I made some minor edits since the last version I sent you, and is shown below to elicit any corrections or additions that need to be made.
Thanks, Ken 01_of_01_D1_1971_914_4_911_Str_Col_Convert_2024_04_15.pdf ( 769.03k ) Number of downloads: 26 |
morehills |
Apr 15 2024, 12:19 PM
@morehills I made some minor edits since the last version I sent you, and is shown below to elicit any corrections or additions that need to be made. Thanks, Ken 01_of_01_D1_1971_914_4_911_Str_Col_Convert_2024_04_15.pdf ( 769.03k ) Number of downloads: 26 Fabulous work Ken. I will start working with it this weekend and let you know if I run into any problems. This will be a huge aid to anyone doing a similar conversion. Thank you, John |
Lo-Fi Version | Time is now: 18th May 2024 - 10:42 AM |
