Jack insert |
Jack insert |
bajafreaks |
Apr 13 2024, 06:21 PM
Member Group: Members Posts: 73 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
Ive removed the jack inserts/points (if thats the correct term?) on the longs since they were rusty. The longs themselves are good. Is there really any reason to weld new ones on since I wouldn't use them anyway and it's not going to be a concours type car.
TROJANMAN |
Apr 13 2024, 07:05 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Only to make it look finished. Most Rocker panels already have the hole cut out. I suppose you could fill that solid too. Just make sure you remove all the rust and seal.
bdstone914 |
Apr 13 2024, 07:31 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have been told that they reinforce a critical fkex area on the longs from flexing.
TROJANMAN |
Apr 13 2024, 08:38 PM
bajafreaks |
Apr 15 2024, 05:05 PM
Interesting, maybe it stiffens up that area due to the fact there's a large hole in the long right behind the jack point.
Does the plastic stopper plug into jack point or into the rocker panel so in other words if the jack point wasn't there how could the plastic stopper be held in place ? |
Cairo94507 |
Apr 16 2024, 06:42 AM
Michael Group: Members Posts: 9,770 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
The plastic cover plugs into the actual jack receiver hole - snugly. (IMG:style_emoticons/default/beerchug.gif)
dr914@autoatlanta.com |
Apr 16 2024, 10:54 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
HansJan |
Apr 17 2024, 11:48 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Why not use them? If the car is solid it should not be a problem.
I use it every time. Jack it up using these points, then place the Jackstands |
Lo-Fi Version | Time is now: 19th May 2024 - 06:28 PM |
