FS: 4 New Drilled Front w/new matched races/bearings & Rear Rotors, fit 70-72 914/4, Zimmerman cross drilled rear & Sebro cross drilled front w/new races/bearings installed |
mr3474 |
Apr 14 2024, 11:10 AM
I'm new here ... Group: Members Posts: 0 Joined: 9-October 22 From: Dahlonega, GA Member No.: 26,902 Region Association: South East States |
Bought from AutoAtlanta (have receipt) check part numbers online
Part # B411407075 Front Rotor 914-4 1970-1972 Cross drilled pair Sebro List $236.76 Part # R91435240110X Rear X Drilled Brake Rotor pair Zimmerman List $231.00 Part # R191598625 Front Wheel Bearing kit 914 pair List $51.90 Installation bearing races inner/outer $40.00 With GA sales tax = cost of $598.82 Selling for $450 pickup (ATL area) or $510 UPS shipped continental U.S. Cash, Zelle, Check OK Did a full brake job with PMB rebuilt calipers, pads, the parts above and new lines prior to making the decision to do a full rebuild of car (metalwork, engine, trans, suspension, interior etc.) Car was never driven with these rotors mounted. The entire suspension was removed, powder coated, remounted and converted to 5 lug with PMB kit. (see 5 - 4 lug polished Fuchs listed in another FS ad here) To recap: these rotors were mounted, then dismounted for a 5 lug conversion. Fronts are NIB with new front inner and outer bearing races and seals installed with matched bearings (greased) with seals. Rears are boxed (not in Zimmerman boxes, but I have the receipt to substantiate). All are ready to install. Super trick drilled rotors dissipate heat better when using high performance pads (it's the little things that make these cars handle and brake better). Contact me with any questions. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st May 2024 - 07:35 PM |
