Shift lever bushing? |
technicalninja |
Apr 17 2024, 01:32 PM
Senior Member Group: Members Posts: 1,220 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Did a bit of searching before this post.
Couldn't find what I'm hunting... I traded shift levers with another member and his lever does not have the brass(?) bushing in the bottom of the lever. This bushing is what the connector pin goes through. Are these available separately or are they considered part of the shift lever? The one I sent had a bushing in it. I've never seen one without the bushing in it until today... |
ClayPerrine |
Apr 17 2024, 02:02 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There were two different shift levers.
The tail shifter had a ball on the end of the shift rod. The side shifter had a coupler on the end of the shift rod. Sounds like you have a tail shifter and need a side shifter. Post a picture of what you are seeing to be sure. |
ejm |
Apr 17 2024, 02:09 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Is #10 what you're looking for?
technicalninja |
Apr 17 2024, 02:27 PM
technicalninja |
Apr 17 2024, 02:32 PM
https://www.autoatlanta.com/porsche-parts/h...rts§ion=701-05
Yike's (IMG:style_emoticons/default/yikes.gif) $20 for what should be a $3.50 bushing... Gotta find an old one (I probably have multiples). Or, build one (IMG:style_emoticons/default/ninja.gif) |
technicalninja |
Apr 17 2024, 02:45 PM
I'm a FULL BLOWN MORON!
Had I spent more time looking at ALL of the packaging and less researching, bother you guys, and wasting everyone's time I'd have not made this thread... That greasy little bastard was stuck to some of the bubble wrap! Ninja ashamed! |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 AM |
