No start 1974 2.0, 1974 2.0 will not start after 2 hour drive |
zaballosc |
Apr 27 2024, 12:59 PM
Newbie Group: Members Posts: 19 Joined: 31-August 15 From: Whitewater, WI Member No.: 19,118 Region Association: Upper MidWest |
Hi all,
We just drove our 914 to Road America after 2 years of incremental work. Over the past year it has started perfectly, and it did the drive perfectly. It has a new starter that has been working great. We parked for registration, and when we got back to the car it would not crank. Fuel pump is running, electrical is working, but the car is not cranking or starting on a bump start. Any ideas? I checked the relays and relay board connections. Currently waiting on a tow. |
emerygt350 |
Apr 27 2024, 02:29 PM
Advanced Member Group: Members Posts: 2,089 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Sounds like you need a Ford solenoid kit, takes 20 minutes to install. {runs for cover}
emerygt350 |
Apr 27 2024, 02:31 PM
If you want to try jumping it in the meantime, just run a screw driver from the hot wire to the solenoid. Make sure it's in neutral.
emerygt350 |
Apr 27 2024, 02:32 PM
You couldn't push start it? Carbs?
And a new starter isn't any guarantee it is a good starter. |
Freezin 914 |
Apr 27 2024, 03:25 PM
Senior Member Group: Members Posts: 855 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
(IMG:style_emoticons/default/agree.gif) A lot of cars suffer from this issue. I am guessing it will start after it cools down.
Freezin 914 |
Apr 27 2024, 04:03 PM
Transmission to body Ground strap and battery ground to chassis ground strap need removal and cleaning with a wire brush annually.
Heat in starter motor creates more resistance. Advance plates in dizzy get stuck in the advance position during hot motor shut down if the oem grease is still in between the plates and they have not been cleaned. |
zaballosc |
Apr 27 2024, 05:55 PM
Hi all, thank you for all of the advice.
I was able to get it towed home, to answer one of your questions it is a FI car. We got it back home on a lift and found that 12.9 volts of power is reaching the starter. So I am thinking that we might have a bad starter. Drats! it was so easy to install when the motor was on the ground, now i'm considering what the swap will be like while it's in the car. |
bkrantz |
Apr 27 2024, 07:58 PM
914 Guru Group: Members Posts: 7,756 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Hi all, thank you for all of the advice. I was able to get it towed home, to answer one of your questions it is a FI car. We got it back home on a lift and found that 12.9 volts of power is reaching the starter. So I am thinking that we might have a bad starter. Drats! it was so easy to install when the motor was on the ground, now i'm considering what the swap will be like while it's in the car. Not a bad job if you can lift the car high enough to work comfortably and SAFELY underneath. |
emerygt350 |
Apr 28 2024, 10:40 AM
Was that 12.9 while you were turning the key? And you want to know how much is hitting the solenoid.
Superhawk996 |
Apr 28 2024, 11:23 AM
914 Guru Group: Members Posts: 5,794 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Seems like everyone has glossed over the fact that it would not bump start?
Don’t know details. Was car rolling fast enough? Did it sputter but not catch and old geezers (like me) got tired pushing. (IMG:style_emoticons/default/blink.gif) The failure to crank and its failure to get root cause solution is so well documented it’s almost ridiculous. Failure to crank and failure to bump start . . . Less so. Where is fuel pump located and was it vapor locked simultaneously? (IMG:style_emoticons/default/confused24.gif) |
emerygt350 |
Apr 28 2024, 03:11 PM
I have had that happen back when I just got the car. Very frustrating.
To replace the starter is just removing the left rear wheel and two bolts. Super easy, but do make sure it's not the low voltage to the solenoid issue first. Not much point in worrying about the bump start issue till you get it to turn over. Is it a 74 or later? I don't know anything about the seat belt cut out but I know people have problems with that too. |
Superhawk996 |
Apr 28 2024, 03:59 PM
Not much point in worrying about the bump start issue till you get it to turn over. Going to have to disagree with you. When troubleshooting electrical issues it’s always important to understand all the symptoms. The failure to bump start could be pointing toward a bad engine to transmission ground which could simultaneously affects both the starter and the ECU grounds. Likewise a bad battery negative ground to chassis would prevent both cranking and bump starting. Just a failure to crank could be excessive voltage drop from ignition switch or it could be the seat belt interlock (assuming that is still in place and not bypassed). In either fails to crank case, it would bump start and run. Similarly a failure to crank (only) could be a starter or solenoid failure and not wiring related. It would still bump start with a failed stater or solenoid. Bottom line: all symptoms matter to avoid needlessly replacing parts and wasting time. |
emerygt350 |
Apr 28 2024, 04:10 PM
I just know many people have issues starting their cars hot on a good day. It wouldn't surprise me if it doesn't kick off on a push start. If it is grounds it doesn't really matter if you fix the push or the starter first both will get you there.
Lo-Fi Version | Time is now: 12th May 2024 - 03:27 AM |
