What clutch for over 250HP? |
gnomefabtech |
May 15 2024, 10:18 PM
Member Group: Members Posts: 111 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
I have a Kennedy Stage 2 Pressure plate with a stock 215mm clutch disc and it's not holding my turbo engine. I'm guessing around 250hp but maybe a bit more.
Has anyone used a more aggressive disc to get a bit more holding power? There are a lot of options out there so I'm hoping to get a bit of guidance so I don't just spend money willy nilly. Thanks. |
Chris914n6 |
May 16 2024, 12:35 AM
Jackstands are my life. Group: Members Posts: 3,333 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I have a Clutch Masters kevlar sport disc that was added to my Kennedy eng swap kit back in the day. If they are still around talk to them. Good for 315+ hp iirc as a combo.
Krieger |
May 16 2024, 08:26 AM
Advanced Member Group: Members Posts: 4,726 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Does Kennedy have a Stage 3?
May 16 2024, 09:15 AM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Does Kennedy have a Stage 3? Yes, they do. I had a similar issue as described above with my KEP setup so i emailed them with the specs of my engine and they send me a (custom?) setup that wasn't listed on their website that has more than enough clamping force for the torque of my engine. (IMG:style_emoticons/default/bye1.gif) |
gnomefabtech |
May 16 2024, 09:49 AM
Thanks for the tips.
I'll call them today. I like the feel of the stage 2 pressure plate so if there is a disc that can get me there that would be awesome. |
FL000 |
May 16 2024, 01:01 PM
Member Group: Members Posts: 399 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
Are you confident your disk/plate are in good shape and cable adjustments correct? I had their stage 2 with my 901 and close to 300 HP/fl-lb torque at the wheels and clutch always felt good.
gnomefabtech |
May 16 2024, 06:23 PM
I'll double check. What disk did you use? I have a stock Sachs
FL000 |
May 16 2024, 08:38 PM
Lo-Fi Version | Time is now: 7th June 2024 - 09:30 PM |
