Production Month from VIN#? |
gnomefabtech |
May 17 2024, 10:23 AM
Member Group: Members Posts: 111 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Hi. I have to order a replacement door jamb VIN decal and was wondering if I can decipher the production month from the VIN number.
VIN# is 4732927649 Pretty annoying that the PO removed it when they painted the car because the CA. DMV is having a fit over it. |
FlacaProductions |
May 17 2024, 10:44 AM
Senior Member Group: Members Posts: 1,615 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
you can get the production date info from the chassis tag on the bottom of the A pillar on the body inside the door.
http://www.914world.com/bbs2/index.php?sho...p;#entry3106577 |
fiacra |
May 17 2024, 11:26 AM
Person.Woman.Man.Camera.TV Group: Members Posts: 344 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Hi. I have to order a replacement door jamb VIN decal and was wondering if I can decipher the production month from the VIN number. VIN# is 4732927649 Pretty annoying that the PO removed it when they painted the car because the CA. DMV is having a fit over it. I went through this as well with my Beetle that had fallen out of the system. You can get a CHP inspection if you wish instead of replacing the door jamb sticker. Free, although it is a pain to set up. You do have to make an appointment. The DMV gave me the paperwork at the time they told me they could not put me back into the system because the door jamb sticker was damaged. Thankfully I got "officer friendly" when I went for the inspection. Not the case when I went to set up the appointment. Good luck! |
gnomefabtech |
May 17 2024, 11:35 AM
Sadly, that tag is gone. I might have it in the piles of stuff that come with the car so I'll search. Is there another location for the chassis number? I found the VIN number on the front fender and it has the windshield tag too. But can't find chassis code so I can figure out the month.
gnomefabtech |
May 17 2024, 11:36 AM
Car sat in a barn in Santa Cruz for 20 years before I got it so all the stuff is out of the DMV system. For obvious reasons they are careful about mystery cars.
Steve |
May 17 2024, 11:50 AM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Check the rear trunk. There might also be a chassis number there.
gnomefabtech |
May 17 2024, 11:56 AM
Where in the trunk? I'll start scraping paint if I know where to start.
FlacaProductions |
May 17 2024, 12:00 PM
passenger side of trunk floor. May be difficult to find/discern - maybe shading over it on some paper with the side of a pencil will help reveal...
gnomefabtech |
May 17 2024, 12:01 PM
Checking now. Thanks.
Steve |
May 17 2024, 12:05 PM
JeffBowlsby |
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Chassis # may also be found handwritten in crayon under the dash surface. Pull the ashtray and use mirrors/good lighting.
FlacaProductions |
gnomefabtech |
May 17 2024, 12:20 PM
Found it.
After some scraping and brushing I see: 2949544 I'll see if I can decode it. Thanks so much. The support this forum gives is mind blowing. |
FlacaProductions |
May 17 2024, 01:25 PM
2949544
1973 29: 29th week starting Monday July 16 4: Built Thursday - july 19 9: Karmann factory 5: means 0-99 cars, “6” would be 100th+ car 44: 44th car - they made about 80/day So...one of the first ones after lunch Thursday July 19, 1973 |
808 WRX |
May 17 2024, 01:58 PM
Member Group: Members Posts: 59 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California |
It looks like you have it figured out...
But, if you didn't have the chassis number you could look through the member vin numbers page and some of them have the chassis numbers or build dates listed and you can usually figure out your month. There is one listed within 10 numbers of yours that shows a build date of July 1973. (IMG:style_emoticons/default/beerchug.gif) http://www.914world.com/bbs2/index.php?act...amp;byYear=1973 |
Geezer914 |
May 17 2024, 04:00 PM
Geezer914 Group: Members Posts: 1,443 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
My number is 092 9015 built 02/75. So this would make it February 25th, (9th week) 2nd day (Tuesday), the 15th car, (015)?
gnomefabtech |
May 17 2024, 08:13 PM
2949544 1973 29: 29th week starting Monday July 16 4: Built Thursday - july 19 9: Karmann factory 5: means 0-99 cars, “6” would be 100th+ car 44: 44th car - they made about 80/day So...one of the first ones after lunch Thursday July 19, 1973 So wait. Was it made in July of 1973? Or July of 1972 for the 1973 model year? I would think that by July they would be making the next years' cars. |
wonkipop |
May 17 2024, 10:16 PM
Advanced Member Group: Members Posts: 4,402 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
2949544 1973 29: 29th week starting Monday July 16 4: Built Thursday - july 19 9: Karmann factory 5: means 0-99 cars, “6” would be 100th+ car 44: 44th car - they made about 80/day So...one of the first ones after lunch Thursday July 19, 1973 So wait. Was it made in July of 1973? Or July of 1972 for the 1973 model year? I would think that by July they would be making the next years' cars. his vin is blah-27649 if you look up at first post. so its at the end. july 73. but a good point. anything that is most other months the k number won't really tell you the year. you need the vin number in combo with k number. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:10 AM |
