914 sitting for 4 years, but turns over - help! |
914zim |
Jul 29 2003, 11:21 AM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Hi guys:
I just found this site and it's very cool! I hope you can give me some advice. (IMG:style_emoticons/default/pray.gif) I'm looking at a '76 914 that has been parked in a garage for 4 years. It ran fine when it was put in storage and looks very clean (seen pics only though). I'm told the tires are still good and the interior is very clean too. The current owner put a fresh battery in it recently and turned it over fine. He's suggesting that I'd need to trailer it home, which seems sensible to me after it's been sitting for so long. Does anyone think I could get it started and chould drive it home? (about 350mi). If I was to trailer it home, what would I have to do it to make it driveable (safe)? 1. change oil. 2. squirt oil (or something) into the cylinders before starting. 3. new battery. 4. change anti-freeze. 5. change brake fluid and bleed. What else? What do you guys think would be a good price for a 914 like this? I'm hoping with a little "tinkering" I could get this car running. Any thoughts/comments are greatly appreciated! Thanks, Andy... |
Qarl |
Jul 29 2003, 02:44 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Spark plugs - cheap and easy
Check Fuel Injection lines (or replace). May be cracked and cause engine to run crappy. Check Fuel Lines (under tank and to engine compartment) Injector lines may be cracked as well Empty and flush tank (gummed up fuel can be nasty). Carbs may have gummed up fuel inside and may be clogged or stick. Check all grounds (battery and tranny). Have a fire extinguisher handy. Flush brake lines. Pray to the 914 gods! |
Lo-Fi Version | Time is now: 17th May 2024 - 10:11 PM |
