2 Pages V < 1 2
> Voltmeter Behavior, Verify Accuracy
windforfun
post Jun 25 2024, 09:03 AM
Post #21
QUOTE(Superhawk996 @ Jun 24 2024, 09:18 PM) *
QUOTE(windforfun @ Jun 24 2024, 10:40 PM) *
Copy that. The power supply reads out to one place & your DMM reads out to two places.
The DMM is more precise & only more more accurate if it's calibrated.
Precision & accuracy are not the same.
Yup
Former USAF electronics tech. Fully familiar with using a $3000 (in 1980s dollars) HP bench DMM with resolution to the 4th decimal place with fully traceable calibration to measure a stupid 9v battery.
No need for that type of accuracy or precision for automotive hobby work.
Even working on complicated electronics it was very rare to ever need that level of accuracy and precision. Flukes were disposed of like toilet paper (IMG:style_emoticons/default/sad.gif)
The sad joke was that if you were going to break or lose a piece of test equipment, make sure it was something big and expensive like a $12k O-scope or $30k spectrum analyzer. They can withhold a Fluke out of your check via GPLD if they felt so inclined (Government property Lost or Damaged) but when you made $12k a year; they were never going to recoup something expensive.
Recognize anything?
emerygt350
post Jun 25 2024, 09:25 AM
Post #22
Just checked the grounds engine to body engine to post, post to wall etc, , all good, less than 0.1 resistance everywhere. Didn't pull the gauge yet to check that. Gotta go shopping first.
Superhawk996
post Jun 25 2024, 09:29 AM
Post #23
QUOTE(emerygt350 @ Jun 25 2024, 11:25 AM) *
.1 ohm x 10amp draw = 1v drop. Even 0.05 ohm x 20 amp load = 1v drop. Unacceptable
Measure voltage drop across the cable while cranking to get an accurate assessment of resistance.
Not sure how you’re wired to battery. Separate independent wire or are you pulling though one of the smaller OEM leads that come off battery positive?
Superhawk996
post Jun 25 2024, 09:33 AM
Post #24
QUOTE(windforfun @ Jun 25 2024, 11:03 AM) *
Recognize anything?
@windforfun
Nice test bench!
Superhawk996
post Jun 25 2024, 09:53 AM
Post #25
gauge #1
Delay and damping behavior related to internal capacitance used for damping.
Sorry for shaky video, couldn't find my little mini tripod.
https://www.youtube.com/watch?v=Hq94EuI9_2g?si=bXc5csV9tLxkHtav
@emeryGT350
ClayPerrine
post Jun 25 2024, 10:31 AM
Post #26
For what it is worth, I use the stock voltmeter as a visual brake light checker. If the brake lights come on, the gauge moves.
If you want to use it for something else, you will have to rewire it to have a connection directly to the battery.
rjames
post Jun 25 2024, 10:47 AM
Post #27
I'm made of metal
emerygt350 might just have a bad gauge. Mine gave inconsistent readings, started reading ~5 volts under, then later 10 under, and then ultimately nothing. Tapping it once in a while would bring it back to life, but eventually it completely died.
Superhawk996
post Jun 25 2024, 11:06 AM
Post #28
QUOTE(rjames @ Jun 25 2024, 12:47 PM) *
Anyone have one opened up?
I’d be curious to verify what’s doing the damping. I’m assuming it’s just a little ceramic disc capacitor via RC circuit.
However based on how this one gauge will linger at 16v position while the other doesn’t (as long) I suspect there is some difference in capacitance and/or resistor values between my two gauges.
emerygt350
post Jun 25 2024, 11:17 AM
Post #29
QUOTE(ClayPerrine @ Jun 25 2024, 10:31 AM) *
Mine is running straight to the battery post. The original wiring now operates a relay.
I suspect it may be failing, as mentioned above. Tapping it causes it to move and it's been slowly getting worse. I checked all the connections behind it when I noticed tapping made a difference (couple weeks ago).
I say less than .1 because on my lowest setting I get a 0 on the resistance.
emerygt350
post Jun 25 2024, 11:20 AM
Post #30
QUOTE(Superhawk996 @ Jun 25 2024, 11:06 AM) *
That is really interesting. The way it sat at 16...
Superhawk996
post Jun 25 2024, 11:24 AM
Post #31
QUOTE(emerygt350 @ Jun 25 2024, 01:20 PM) *
Would be totally consistent with an RC charging constant that takes time both to build up - which will happen more slowly at low voltage and will take longer to bleed off at high voltage
I’ll try to get another video of the other gauge up later so you can see the difference between the two.
The absolute worst case is that it gets mechanically “stuck” up there after being driven to full scale but I don’t think so based on how consistently it releases.
Superhawk996
post Jun 25 2024, 05:18 PM
Post #32
Gauge #2
Slightly different damping behavior. Perhaps a little slower to rise up to voltage when starting from 8 volts. Much quicker to release once it has been brought up to 16 volts.
https://www.youtube.com/watch?v=9ar5kOuEUAk
@emerygt350
emerygt350
post Jun 25 2024, 07:19 PM
Post #33
It is interesting how in both cases they behaved best at 12 volts but one was slow lower and the other misbehaved higher.
Superhawk996
post Jun 25 2024, 07:54 PM
Post #34
QUOTE(emerygt350 @ Jun 25 2024, 09:19 PM) *
The variance in damping isn’t terribly surprising. Assuming I’m right that they are using an RC circuit for damping, the tolerance of resistors would have been +/- 10% and capacitors could be 20% or more if there is an electrolytic capacitor in there. And that would be before 50 years of aging.
I think it’s a combination of what was said earlier - cheap gauge built to do a basic job at a an affordable price point.
However what has always been pretty clear to me is that the accuracy is pretty good. 0.5 volt +/- really is no big deal in the scheme of things.
Add in 50 year old aging wire harness with convoluted 12v+ sourced off the brake lamp circuit and you get the typical bounce as lights cycle on/off.
Let us know what you find with yours.
If I ever find one that is in-op, I’ll tear it down to verify what is being used for damping.
emerygt350
post Jun 26 2024, 05:02 AM
Post #35
I finally dug into the console. I had compared the voltage on the dmm at the gauge to the battery, and they were off. The gauge was showing pretty close to what it was getting. The DACO has wired his Autometer AFR into the same relay controlled circuit as the gauge, so the gauge is not alone on that circuit (completely forgot). It's the damn O2 sensor heater. A little tiny 20 gauge or less wire takes a big hit while the sensor is heating. Disconnected the AFR and all was good.
Superhawk996
post Jun 26 2024, 06:08 AM
Post #36
Now those delays and variable voltage drops you were seeing make sense.
emerygt350
post Jun 26 2024, 06:13 AM
Post #37
QUOTE(Superhawk996 @ Jun 26 2024, 06:08 AM) *
sigh. All I had to do was hook the o2 heater wire to the old lines that are now triggering the relay rather than the hot going to the gauge and all is good.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 11th July 2025 - 10:52 AM
