> 914World Classifieds Rules
> 914-6 PMS Engine Mount & Conversion Oil Tank, Patrick Motorsports New In Box Items
Vysoc
post Jul 2 2024, 07:12 PM
Vysoc
Hello,
Up for sale will be two separate items:
Item 1) Engine Carrier Mount - Porsche 914 Bulk Head to Porsche 6 Cylinder Engine Conversion. Utilizes Poly Urethane Bushings TIG Welded steel - Black Powder Coated Finish. 13.5 Lbs. Has option of welding in or bolting to existing chassis.
$350.00 + Shipping - SOLD
Item 2) 914-6 Conversion Oil Tank -
Fits all Porsche 914-4 & 914-6 Chassis. PMS's Re-Production is a copy of the original 914-6 Steel Oil Tank. Made of .120/1/8" Aluminum and TIG Welded - The tank includes a 30mm or 16AN Feed and 26mm or 12 AN fittings.
This tank is a direct replacement for the factory metal oil tanks that with age rust out from the inside. With this Aluminum Tank that problem is gone and the Aluminum Tank helps to cool the oil faster than the stock tank.
Also included is the Oil Filler Neck Kit -
Aluminum reproduction unit - for original or reproduction Porsche 914-6 Oil Tank - Includes Stainless Steel Oil Level Dip Stick. Yellow Zinc plated seal cap. High quality silicone hose with stainless steel clamps.
Also included is the Oil Filter Console -
Billet Aluminum Black Anodized, includes hardware & O-Ring, uses late style Mahle OC-54 Oil Filter.
All three items for Oil Tank will be sold together.
$750.00 + Shipping
Please PM for any questions you may have about either of these items.
Thank you,
Vysoc
Vysoc
post Jul 5 2024, 05:36 AM
Vysoc
Bump or Best Offer.
Vysoc
post Jul 9 2024, 05:10 PM
Vysoc
Bump......Price Reduction, these are both New In Box.
MikeV914
post Jul 10 2024, 03:03 PM
I'm new here ...
Hello,
Sent you a PM on the engine mount
Mike
JOEPROPER
post Jul 10 2024, 03:08 PM
The answer is "no" unless you ask...
I'm interested in the mount also if the first guy passes
Vysoc
post Jul 10 2024, 07:15 PM
Vysoc
QUOTE(MikeV914 @ Jul 10 2024, 05:03 PM) *
Hello,
Mike
Thanks Mike I sent you a PM.
Vysoc
Vysoc
post Jul 10 2024, 07:17 PM
Vysoc
QUOTE(JOEPROPER @ Jul 10 2024, 05:08 PM) *
Joe you are first in line waiting for response from Mike.
Thank you,
Vysoc
Vysoc
post Jul 11 2024, 05:15 PM
Vysoc
Engine Mount from Patrick Motorsports Sold!
Vysoc
Vysoc
post Jul 18 2024, 06:10 AM
Vysoc
PMS Oil Tank/Filler Neck/Console - SOLD
Thank you,
Vysoc
- Lo-Fi Version Time is now: 5th July 2025 - 10:09 PM
