Front fender removal |
echocanyons |
Jul 29 2003, 11:55 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
When one has to remove the front fenders is it just a matter of popping the tack welds?
Where are all of the welds located? Can it be expected to match a new fender up easily or is it a painstaking ordeal? Are fenders available? The car I just purchased has been lightly tapped in the front(or more likely lightly tapped sonmething). Because of this it has very minor damage around the turn signal. I was told that the damage could be repaired by and experienced person without bondo but I wonder if it would make more sense to just replace the fender |
URY914 |
Jul 29 2003, 02:36 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,883 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've cut my fenders off and it was no easy chore. It has to be easier to repair the existing fender. But if you need to cut a section out of a good fender to repair yours, I still have mine if you need them.
Paul |
Lo-Fi Version | Time is now: 29th May 2024 - 02:54 AM |
