> Battery Cable Sizes, what are they
76-914
post Jul 9 2024, 10:47 AM
I'm replacing the battery cables on 2 914's. Are they 4ga? Any recommendations for or against cable types? Welding cable, electrical cable, strand count, sheathing minimum's, etc. TIA, Kent
Superhawk996
post Jul 9 2024, 05:36 PM
QUOTE(76-914 @ Jul 9 2024, 12:47 PM) *
4ga is sufficient for 914 cold cranking draw + some margin.
I really like welding style cable with the fine strands - super flexible. However beware regular welding cable may just be EPDM rubber jacket and not rated for oil / high temp. Long ago I used regular welding cable to relocate battery to the frunk. To be honest it held up fine but didn’t run in the engine compartment.
Crimping lugs properly requires special tool. PITA. Local shops can usually do the crimp for you.
Check around plenty of sources both local and on the web similar to
https://www.batterycablesusa.com/0000-gauge...e-black-4-0-awg
Note: I haven’t used the linked company above - just for photo reference and SAE specs info
914Sixer
post Jul 9 2024, 06:31 PM
Battery to starter cable length is 56 inches.
jim_hoyland
post Jul 9 2024, 07:12 PM
Get that VIN ?
Yup, 56”
It’s yours if you want it.
FlacaProductions
post Jul 9 2024, 08:23 PM
Funny that you mention BatteryCablesUSA, @Superhawk996 - I recently ordered the following from them in red at 57" and both connector ends 5/16 inch (M8) (fits my connector setup at the battery)
It's at the shop - I'll see it in a few weeks.
https://www.batterycablesusa.com/4-gauge-aw...cable-with-ends
Superhawk996
post Jul 9 2024, 08:51 PM
QUOTE(FlacaProductions @ Jul 9 2024, 10:23 PM) *
Funny that you mention BatteryCablesUSA, . . . I recently ordered . . . from them
Let me know how they do. I’ve looked at them several times but have not pulled the trigger.
Not as easy for me to find local suppliers now that I’m not in a metro area. Always good to know who the good online suppliers are.
@FlacaProductions
technicalninja
post Jul 9 2024, 08:56 PM
+1 (IMG:style_emoticons/default/agree.gif)
I'm plus 1 with welding cables as well.
Never had a failure and some of mine have been in for 25+ years.
Get the good stuff. As welders use LONG cables it's usually cheaper than automotive grade stuff and has at least double the conductors.
post Jul 9 2024, 09:17 PM
All the info I needed. Thx Gentlemen. (IMG:style_emoticons/default/beerchug.gif)
TonyH
post Jul 28 2024, 10:45 AM
Region Association: France
Good afternoon everyone,
A quick question please. What is the ideal size for a battery for a 1.8 914 plus the amp hour rating?
Many thanks from sunny north west France.
Superhawk996
post Jul 28 2024, 11:55 AM
QUOTE(TonyH @ Jul 28 2024, 12:45 PM) *
Battery size is groupe 42
Capacity will be around 40-50 Ah
TonyH
post Jul 29 2024, 03:57 AM
QUOTE(Superhawk996 @ Jul 28 2024, 11:55 AM) *
Very many thanks, but in Europe they don't use that group style of classification they always use a code but its the actual size I am after.
Any ideas please?
- Lo-Fi Version Time is now: 10th July 2025 - 06:04 PM
