Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
> 901.333.511.00, Stop washer
DennisV
post Jul 10 2024, 04:27 PM
#5 parts catalog diagram 901-333-511-00 Stop washer for rear shocks. Non-metal rubber or plastic type of material. OD: ~ 54 mm.
Photo credit Auto Atlanta.
Replies(1 - 2)
davep
post Jul 10 2024, 07:46 PM
914 Historian
The grooves act as a vent to keep the stopper (6) from acting as a vacuum pump and sucking fluid past the shaft seal.
DennisV
post Dec 27 2024, 08:41 PM
While the original part is NLA, there is a shipping part (as of 2024) that appears to be a similar material and has grooves as mentioned by Jeff.
911-333-511-00 has Slightly larger at 58mm.
- Lo-Fi Version Time is now: 11th July 2025 - 02:19 AM
