| Geezer914 |
Jul 27 2024, 04:37 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,260 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Spent the day at the Millville NJ race track today 85 degree weather. Went to start the car at 5pm and nothing happened. Battery is good, turn the key and nothing, no clicking or anything. Gauges work, gas gauge etc. The guys gave me a push start and it started, drove home for 45 minutes with no problem. Pulled into the garage, shut it off, turned the key and it started! I have the Ford 6 volt starter solenoid installed between the starter and the ignition switch. So where do I start? Being it started, I can't trust the car starting if I stop somewhere and shut it off. WTF?
Geezer914 Starting issue Jul 27 2024, 04:37 PM
ClayPerrine You may have a bad ignition switch.
Check the o... Jul 27 2024, 04:43 PM
StarBear A trick that worked on mine when I had that proble... Jul 27 2024, 05:00 PM
Superhawk996 As I continue to preach, the hot start relay is si... Jul 27 2024, 07:43 PM
emerygt350 What year? This isn't the dreaded seatbelt sw... Jul 28 2024, 05:48 AM
Geezer914 It's a 75. Seatbelt relay was disconnected lo... Jul 28 2024, 11:30 AM
76-914 You could have a dead spot on the starter. If so, ... Jul 28 2024, 11:50 AM
emerygt350 Mine is already starting to go and it isn't ev... Jul 28 2024, 06:15 PM
Geezer914 Installed new 6 volt Ford Solenoid and changed the... Jul 31 2024, 12:06 PM
Superhawk996
Installed new 6 volt Ford Solenoid and changed th... Jul 31 2024, 12:22 PM
Spoke
Installed new 6 volt Ford Solenoid and changed th... Jul 31 2024, 12:36 PM
Geezer914 What should be the voltage at the end of the yello... Jul 31 2024, 12:31 PM
Superhawk996
What should be the voltage at the end of the yell... Jul 31 2024, 01:16 PM
930cabman
What should be the voltage at the end of the yell... Jul 31 2024, 01:27 PM
Geezer914 Thanks for the replies. Will test out the starter... Jul 31 2024, 12:46 PM
Geezer914 So if I have battery voltage at the yellow wire wh... Jul 31 2024, 01:42 PM
Shivers
So if I have battery voltage at the yellow wire w... Jul 31 2024, 02:30 PM
930cabman
So if I have battery voltage at the yellow wire w... Jul 31 2024, 04:03 PM
Superhawk996
So if I have battery voltage at the yellow wire ... Jul 31 2024, 05:01 PM
930cabman
[quote name='930cabman' post='3159565' date='Jul ... Jul 31 2024, 05:39 PM
904svo Check the engine ground strap on the transmission,... Jul 31 2024, 02:39 PM
sdoolin Watching/reading this thread as I am having a very... Jul 31 2024, 03:26 PM
East coaster I hope you get your starting issue resolved easily... Jul 31 2024, 04:52 PM
Geezer914
I hope you get your starting issue resolved easil... Aug 1 2024, 06:59 AM
ClayPerrine What year is your 914?
If it a 74 or later, it ... Jul 31 2024, 08:46 PM
Geezer914 UP early at 6am while it's cool. Cleaned the ... Aug 1 2024, 04:47 AM
930cabman
UP early at 6am while it's cool. Cleaned the... Aug 1 2024, 04:50 AM
ClayPerrine
UP early at 6am while it's cool. Cleaned th... Aug 1 2024, 05:06 AM
Superhawk996 Now that it cranks - go back to post #4.
Read th... Aug 1 2024, 06:50 AM
Geezer914 I think I found the culprit. I ordered a new Ford... Aug 1 2024, 06:53 AM
Superhawk996
I think I found the culprit. I ordered a new For... Aug 1 2024, 06:56 AM
Geezer914 The ground strap was new when I installed the rebu... Aug 1 2024, 07:05 AM
Superhawk996 Just to be clear - I’m not saying ground is the ... Aug 1 2024, 07:24 AM
Geezer914
Just to be clear - I’m not saying ground is the... Aug 1 2024, 07:58 AM
Robarabian I hate to suggest this... but have you cleaned the... Aug 1 2024, 07:32 AM
Geezer914 Battery voltage reads 12.66 volts. Yellow wire wi... Aug 1 2024, 08:54 AM
Superhawk996
Battery voltage reads 12.66 volts. Yellow wire w... Aug 1 2024, 09:27 AM
dr914@autoatlanta.com 1. make sure the car is charging at 13.6
2 clean t... Aug 1 2024, 09:15 AM
Geezer914 Starter is an IMI high torque starter. Battery te... Aug 1 2024, 09:34 AM
Superhawk996
Starter is an IMI high torque starter. Battery t... Aug 1 2024, 10:10 AM
Geezer914 So what you are saying my ignition switch could be... Aug 1 2024, 12:12 PM
Superhawk996
So what you are saying my ignition switch could b... Aug 1 2024, 12:22 PM
Geezer914 I can fix anything mechanical. Electrical issues,... Aug 1 2024, 12:55 PM
Superhawk996
I can fix anything mechanical. Electrical issues... Aug 1 2024, 01:16 PM
Superhawk996 If you want to try something simple to see if you ... Aug 1 2024, 01:23 PM
Geezer914
If you want to try something simple to see if you... Aug 1 2024, 03:19 PM
ClayPerrine I agree with this testing methodology. Let's ... Aug 1 2024, 01:39 PM
930cabman Background:
mostly average hit/miss backyard hack... Aug 1 2024, 04:08 PM
Geezer914 Battery ground to yellow wire reads 11.66 volts. ... Aug 1 2024, 04:40 PM
Superhawk996
Battery ground to yellow wire reads 11.66 volts. ... Aug 1 2024, 06:10 PM
Superhawk996 I know that’s a lot to digest.
Happy to answe... Aug 1 2024, 06:14 PM
Geezer914 Voltage across battery posts reads 12.44 . Voltag... Aug 1 2024, 06:37 PM
Superhawk996
Voltage across battery posts reads 12.44 . Volta... Aug 1 2024, 07:13 PM
Geezer914
Voltage across battery posts reads 12.44 . Volt... Aug 3 2024, 08:47 AM
Geezer914
[quote name='Superhawk996' post='3159787' date='A... Aug 3 2024, 08:54 AM
ClayPerrine I would start with replacing your negative battery... Aug 2 2024, 01:23 PM
Geezer914 That is the ground strap that I have new, last spr... Aug 2 2024, 02:47 PM
ClayPerrine
That is the ground strap that I have new, last sp... Aug 2 2024, 03:01 PM
Geezer914
That is the ground strap that I have new, last s... Aug 2 2024, 03:32 PM
Geezer914 What am I measuring this against? Aug 3 2024, 08:54 AM
Superhawk996 You are measuring the voltage drop across the nega... Aug 3 2024, 11:09 AM
Geezer914 I do not have that scale on my meter. Aug 3 2024, 12:28 PM
Superhawk996
Use lowest... Aug 3 2024, 12:51 PM
Geezer914 RE: Starting issue Aug 3 2024, 01:24 PM
Superhawk996 Pulled the manual for your DMM. It is auto-range ... Aug 3 2024, 01:54 PM
Superhawk996 You could also engage the Min/Max feature to be ab... Aug 3 2024, 02:07 PM
technicalninja :agree: :agree: :agree:
I use the min/max feat... Aug 3 2024, 02:49 PM
Geezer914 Just did the test. Meter jumped from 12.14 to 12.... Aug 4 2024, 09:08 AM
Superhawk996
Just did the test. Meter jumped from 12.14 to 12... Aug 4 2024, 12:19 PM
Superhawk996 I’ve drawn the schematic your car as you’ve la... Aug 4 2024, 01:16 PM
Geezer914 Thanks, we will resume this on Monday. Aug 4 2024, 04:47 PM
Superhawk996
Check bac... Aug 4 2024, 05:48 PM
Superhawk996 Ok so here’s what I think happened when you meas... Aug 5 2024, 08:52 AM
Geezer914 installed the new remote starter solenoid. Starte... Aug 5 2024, 11:44 AM
Superhawk996
installed the new remote starter solenoid. Start... Aug 5 2024, 11:56 AM
Geezer914 I have a 1.5 ma draw from the negative battery pos... Aug 5 2024, 01:03 PM
Superhawk996
I have a 1.5 ma draw from the negative battery po... Aug 5 2024, 06:50 PM
Geezer914 Found the current draw, I had extra relays stored ... Aug 7 2024, 05:32 AM
Superhawk996 Good find.
If it were me, I’d want to see if t... Aug 7 2024, 06:06 AM
TonyH
Good find.
If it were me, I’d want to see if ... Aug 10 2024, 09:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:10 PM |
