2 Pages V < 1 2
> LED Instrument Illumination
lapuwali
post Aug 26 2005, 12:53 PM
Post #21
Not another one!
QUOTE (bd1308 @ Aug 26 2005, 09:58 AM)
who said they weren't dimmable????
i've played with LEDs for years....there as dimmable as a regular bulb.
I did.
Here's an example of why, and a dimmer that works, but isn't just a pot:
Dimming LEDs
It may well be that NH Speedo provides a circuit board for the inside of the gauge with several LEDs, a voltage regulator, a transistor, and a handful of resistors, as shown here. They could also be using a simple timer to produce dimming via PWM. None of this is all that expensive, but it's more than just a bulb, a wire, and a pot.
mightyohm
post Aug 26 2005, 01:01 PM
Post #22
If I were doing this I would dim them with PWM in response to the voltage change across a voltage divider formed by the dimmer knob and a dropping resistor. The downside is you would need a custom circuit to connect all the LEDs to and you wouldn't be able to use them as a drop in for regular light bulbs. (Unless you included a tiny dc-dc converter and the pwm circuit inside the base of each bulb.)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 1st May 2026 - 09:53 AM
