Trailer Question, Different Connectors |
richardL |
Jul 29 2003, 02:05 PM
Senior Member Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None |
Can someone explain the standard types of connectors between the tow vehicle and a typical trailer.
Mostly I recall seeing a circular plug, 6 pin I think. However, my Explorer and other vehicles I've looked at has an inline 4 pin connector attached. So, if I wanted to tow do I have to buy an adapter to the circular connector, or do trailers have a 4 pin inline connector or what? What type of connector would be found on most car trailers? Thanks, Richard |
tryan |
Jul 29 2003, 02:17 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
four pin is most common. my trucks always come with a 7 (round)to 4 (rectangular)adapter. pollack? is the brand name.
Mueller |
Jul 29 2003, 02:25 PM
Trailer Wiring Connectors
My truck has the 7-pole round connector which uses an adaptor to go the the 4-pin flat connector of my trailer. 4-pin, basic lights 7-pin, lights plus electric brakes if trailer is so equipped (and truck has the modual) |
URY914 |
Jul 29 2003, 02:28 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 119,619 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
What Mueller said.
Paul |
EdwardBlume |
Jul 29 2003, 10:43 PM
Like you my 4Runner had the inline 4 pin. When I bought a trailer (great deal BTW) the shop told me to go to a round 7 pin so I could control the brakes on the trailer.
I went to an RV shop and for $400 got the wiring and brake controller bought and installed. I think it only uses 6 of the connections, with the 7th available for other apps. Good luck!! (IMG:style_emoticons/default/cool.gif) |
URY914 |
Jul 30 2003, 05:35 AM
The 7 pins are for:
1. right turn 2. left turn 3. brake 4. ground 5. back-up (optional) 6. brakes (optional) 7. extra pin (use for running lights, interior light, etc) Paul |
Lo-Fi Version | Time is now: 28th March 2024 - 06:20 PM |
