| yeahmag |
Aug 20 2024, 03:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,479 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
I accidentally purchased (who knows how) 911 rear discs (SEB-205195C) instead of the 914-6 discs (SEB-105184C) I typically use. I run late 914-4 front calipers on the rear with a bias valve. I assume there is no way these will fit... Correct?
911 SC rotor Diameter: 290mm Type: Internally vented Brake Disc Thickness: 20mm vs 914-6 rotor Diameter: 286mm Thickness: 10.5mm |
| bdstone914 |
Aug 20 2024, 08:18 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,289 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You would need an M caliper or simular. What are yiu3running on the front?
@yeahmag ' date='Aug 20 2024, 02:39 PM' post='3163083'] I accidentally purchased (who knows how) 911 rear discs (SEB-205195C) instead of the 914-6 discs (SEB-105184C) I typically use. I run late 914-4 front calipers on the rear with a bias valve. I assume there is no way these will fit... Correct? 911 SC rotor Diameter: 290mm Type: Internally vented Brake Disc Thickness: 20mm vs 914-6 rotor Diameter: 286mm Thickness: 10.5mm [/quote] |
| yeahmag |
Aug 20 2024, 09:38 PM
911M 3" caliper in front. I decided it makes sense to just return the 911 rotors and rebuy the 914-6. Expensive (shipping) mistake on my part.
| mlindner |
Aug 21 2024, 09:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,753 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Hi Aaron, I thought I was the only one putting front calipers on the rear. I run SC calipers on the front and braking is very balanced. My rear rotors are 914 solids redrilled for five lug. Best, Mark
| dr914@autoatlanta.com |
Aug 21 2024, 09:34 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,233 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
and the offset is different as well
I accidentally purchased (who knows how) 911 rear discs (SEB-205195C) instead of the 914-6 discs (SEB-105184C) I typically use. I run late 914-4 front calipers on the rear with a bias valve. I assume there is no way these will fit... Correct? 911 SC rotor Diameter: 290mm Type: Internally vented Brake Disc Thickness: 20mm vs 914-6 rotor Diameter: 286mm Thickness: 10.5mm |
Lo-Fi Version | Time is now: 15th April 2026 - 03:52 AM |
