| jbyron |
Aug 21 2024, 07:09 PM
Jamie ![]() ![]() Group: Members Posts: 155 Joined: 17-July 07 From: Ballwin, MO Member No.: 7,916 Region Association: Upper MidWest |
So I had no problem pulling the speedo out of the cluster, removed the lighting and spade connector, and unscrewed the retainer on the speedometer cable. But the cable doesn't want to come out of the speedometer housing, and I don't know how much is too much force. Is it ok to grip the brass collar sticking out of the cable housing and wriggle it loose, or does that stay in the speedometer? Also, I don't see where to disconnect the reset cable - where on the dash do I look for that?
Thanks for any guidance. |
| hndyhrr |
Aug 21 2024, 07:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest
So I had no problem pulling the speedo out of the cluster, removed the lighting and spade connector, and unscrewed the retainer on the speedometer cable. But the cable doesn't want to come out of the speedometer housing, and I don't know how much is too much force. Is it ok to grip the brass collar sticking out of the cable housing and wriggle it loose, or does that stay in the speedometer? Also, I don't see where to disconnect the reset cable - where on the dash do I look for that? Thanks for any guidance. be gentle but tug on it. reset cable stays on speedo. That is how it is on my 70 1.7 |
| RAX914 |
Aug 21 2024, 07:18 PM
Member ![]() ![]() Group: Members Posts: 109 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None
Disconnect the reset cable from the knee pad. It should be under the cigarette lighter. The reset cable will come out still connected to the speedometer
| bdstone914 |
Aug 21 2024, 07:21 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,289 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
So I had no problem pulling the speedo out of the cluster, removed the lighting and spade connector, and unscrewed the retainer on the speedometer cable. But the cable doesn't want to come out of the speedometer housing, and I don't know how much is too much force. Is it ok to grip the brass collar sticking out of the cable housing and wriggle it loose, or does that stay in the speedometer? Also, I don't see where to disconnect the reset cable - where on the dash do I look for that? Thanks for any guidance. The reset cable is held into the speedo with a plastic clip. Pinch it with a small pair of pliers and pop ot out. You can disconnecit from under the dash. Depending on the year it will have a steel or plastic knob. The pkastic knob pylls off. The steel knob has a 2mm set set that needs a jewelers screwdrover to loosen. After removing the knob there is a threaded retaining ring and washer. Wiggle the cable back and forth to see if you can break it loose. If you disconnect it at the trans you can pull the gauge out father and it should help to work on it. |
| jbyron |
Got it - thanks!
| PaIsa |
Aug 22 2024, 05:29 AM
Member ![]() ![]() Group: Members Posts: 133 Joined: 13-June 24 From: Quebec, Canada Member No.: 28,180 Region Association: Canada
Sorry for my ignorance, but reset cable??? To reset what, trip-o-meter?
Please be gentle, still learning about these cars! (IMG:style_emoticons/default/smile.gif) |
| Cairo94507 |
Aug 22 2024, 06:47 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,611 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Yup. the trip odometer. (IMG:style_emoticons/default/beerchug.gif)
| Shivers |
Aug 22 2024, 08:24 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,348 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Sorry for my ignorance, but reset cable??? To reset what, trip-o-meter? Please be gentle, still learning about these cars! (IMG:style_emoticons/default/smile.gif) Out of the three teeners I have had, only one still had the reset cable. And it is not an obvious knob, it's a little thing under the knee pad |
| PaIsa |
Aug 22 2024, 08:50 AM
Sorry for my ignorance, but reset cable??? To reset what, trip-o-meter? Please be gentle, still learning about these cars! (IMG:style_emoticons/default/smile.gif) Out of the three teeners I have had, only one still had the reset cable. And it is not an obvious knob, it's a little thing under the knee pad Yes I saw this knob and felt the cable going back behind the dash but did not know what it was. I thought it was a fused or something else installed by someone else. |
| FlacaProductions |
Aug 22 2024, 11:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,183 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Sorry for my ignorance, but reset cable??? To reset what, trip-o-meter? Please be gentle, still learning about these cars! (IMG:style_emoticons/default/smile.gif) and if you're still learning about 914's don't learn the hard way and reset the trip meter while you're moving. it'll strip an internal gear. Reset while stopped ONLY. |
Lo-Fi Version | Time is now: 16th April 2026 - 12:05 AM |
