straight cut cam gears, why? why not? |
Jake Raby |
Aug 26 2005, 08:43 PM
I don't see that one happening anytime soon- Being a professional asshole is a delightful position to have!
sean_v8_914 |
Aug 26 2005, 09:06 PM
asshole or not, I agree. I have seen some "car of the year" awards that just didnt make sense...but I am sure they made dollars for teh magazine in wich they were displayed. I.E. H-1 Hummer? SUV of teh year? Have you ever looked under that thing? its a blazer with a live axle rear. I think Le Car was car of teh year. so was teh Alliance
Money talks. |
Type 4 Unleashed |
Aug 27 2005, 12:40 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
[QUOTE]No good in a daily car, or even a weekender. They're WAY loud, and can often completely dominate the engine note. I, run strait cuts, daily driver, 1,000 - 1,500 miles a week. Loud? Hell Yes. Why? I'am running alot of spring pressure, (SBC springs), the cam, lifters and springs are a proven combination, one thing about the springs, they will never let the valves float, miss shift or otherwise. This combo is what I'll use for my .600" lift cam. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
Type 4 Unleashed |
Aug 27 2005, 10:18 PM
Britain, what cam you running, springs and what bore & stroke? And I see you had your crank dowled. |
Britain Smith |
Aug 27 2005, 11:32 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
The motor is 78 stroke and 98 bore, making is a 2353cc. It is running a custom grind cam from Jake that was designed with the flow rates, turbo charging, Pauter rockers, etc. in mind. I am not sure of the specific specs, but I know that it is a split duration between intake and exhaust.
-Britain |
Brett W |
Aug 27 2005, 11:39 PM
Then how do you know if it is installed right? |
Jake Raby |
Aug 27 2005, 11:59 PM
He got a cam card....
Brett W |
Aug 28 2005, 10:17 AM
Without a degree wheel how will he know if the cam is installed advanced, retarded etc?
Jake Raby |
Aug 28 2005, 11:40 AM
I guess he'll just stab it and go! I don't know what advance/retard washers he used when it was assembled..... I'd personally run this cam straight up as long as it degreed correctly.
Most DIY guys just don't understand degreeing in a cam- that can really bite you in the ass though! BTW- I have seen one more web cam be out like the one you got. I put every cam in the cam doctor and found one on a 114 L/C that should have been on a 108- it was the cam for the Super 2 Liter- it degreed in perfectly after I had them repair the issue. |
IronHillRestorations |
Aug 28 2005, 01:53 PM
Yet another product dumped on the market from pure advertising! A solution for a problem that doesn't exist. Just cause somebody makes it, and somebody else sells it, and some PR guy that's never had a wrench in his hand in his life comes up with a BS rap that sounds plauseable, IT STILL DOESN'T MAKE IT A GOTTA HAVE PIECE! |
Britain Smith |
Aug 28 2005, 03:44 PM
I installed that cam using the zero degree washers. I have a conceptual understanding of degree'ing the cam, but I have never had any experience playing with it. -Britain |
Aug 28 2005, 04:58 PM
that could get spendy! |
Brett W |
Aug 28 2005, 08:48 PM
Its not just a Web problem. I think it is me. Everytime I do some custom stuff I have to keep going back and forth to get the manufacture to get it right. I must be the only person on the planet that won't put my name and reputation on garbage.
Most people can get by with just pokin' the cam in and hopin' it is right. You do what lets you sleep at night. |
Jake Raby |
Aug 28 2005, 08:53 PM
Nope two of us! I get lucky a lot of times... I honestly think that sometimes when guys off the street order somet things they get "Whatever".... Web knows that I'm gonna throw every cam on the Doctor and degree them all in when I build an engine so *maybe* things are more checked out... Also I only buy TWO cams off their shelf- all the rest are custom so they have to be made... Luck sometimes runs out- Like it has for me with this FP engine... Its together and rewady for the dyno in the morning, but EVERY part of it has haunted me.... over 125 hours in the past 7 solid days of fiddling with it......... Its gonna be another all nighter just to get it up on the dyno and hook the logger to it and crank for oil pressure... |
Brett W |
Aug 28 2005, 09:22 PM
Good luck.
gothspeed |
Apr 23 2018, 05:16 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I know this thread is over a decade old .... back then peeps thought available straight cut cam gears were not good quality. I figured I would ask if this 'situation' has changed since then.
Is anyone running straight cut cam gears now? This vid shows a VW type 4 with straight cut gears. I think it sounds pretty good (IMG:style_emoticons/default/sunglasses.gif) https://www.youtube.com/watch?v=WEF-5QtVWqM |
914werke |
Apr 23 2018, 06:55 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I agree. But I am biased since Im hooked on the sound of the gear driven cams & .5 v8 rumble from my VFR!
Mueller |
Apr 23 2018, 09:14 PM
I know this thread is over a decade old .... back then peeps thought available straight cut cam gears were not good quality. I figured I would ask if this 'situation' has changed since then. Is anyone running straight cut cam gears now? This vid shows a VW type 4 with straight cut gears. I think it sounds pretty good (IMG:style_emoticons/default/sunglasses.gif) https://www.youtube.com/watch?v=WEF-5QtVWqM ^ I like it, almost has a /6 motor sound. I think those long chains on the /6 make up some of the "noise" that we love. |
eeyore |
Apr 23 2018, 10:48 PM
pt_700 |
Apr 24 2018, 12:35 PM
Senior Member Group: Members Posts: 1,090 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
I agree. But I am biased since Im hooked on the sound of the gear driven cams & .5 v8 rumble from my VFR! I miss my '90 VFR so tremendously. Stock headers with a slip on. Revving up through 5,000 RPM and beyond -- words fail me... + another on the vfr's. mine was an '87, dark blue with a yoshi slip-on. best sounding bike motor ever, in my opinion. nice power characteristics too, torque like a v-twin and top end like an in-line 4. now back to our regularly scheduled programming... |
Lo-Fi Version | Time is now: 26th April 2024 - 08:25 PM |
